Help Throttle Staying Open
Old Sep 22, 2021 | 05:48 PM
rushingad's Avatar
rushingad
Stage IV
Default Help Throttle Staying Open
I'm looking for some help with my 2021 FXST. I went to go for a ride first time in 2 weeks and my throttle is staying open slightly, idling about 1500-1800 rpm. I can roll the trottle forward slightly and it returns to a normal idle, but opens right back up as soon as I release. The bike will cruise around 30 mph on its own in 4th gear. Is there any way to adjust the throttle, or any idea what would have caused this? The bike was running fine last time I rode. Any advice would be appreciated before the Harley shop says it's not an issue covered under warranty lol Thanks
Old Sep 22, 2021 | 06:24 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Why would the HD shop say that? The bike is under FULL warranty unless you've mucked around with it.
Old Sep 22, 2021 | 06:55 PM
rushingad's Avatar
rushingad
Stage IV
I'd hope they wouldn't it. When I called they mentioned something about an adjustment it needed. I just always expect to be charged when I go in there. Felt like they might think it was something that I did while I was riding.
Old Sep 22, 2021 | 07:11 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Do the idle TPS reset procedure.
Don't touch the throttle .. kill switch in the run position ...
Turn ignition switch on, wait for engine light to go off (10 seconds), turn ignition off (10 seconds).
Do this 4 times, then start the engine. This resets the computer.
Note: when shutting down the engine make sure it's at idle. Don't blip the throttle, and don't shut it down on cold idle. The computer remembers the last rpm at shutdown and sets the idle to that.
https://www.harley-davidsonforums.co...idling.280705/
Old Sep 22, 2021 | 09:20 PM
rushingad's Avatar
rushingad
Stage IV
Awesome man it's normal now. Good chance I may have killed it before it had idled all the way down last time I rode. Thanks so much bud
DelPantalone
2014-2024 Touring Models
15
Sep 26, 2019 12:22 PM
cc1967
General Topics/Tech Tips
Sep 19, 2015 02:15 PM
monsterglide2008
Sep 5, 2009 07:32 AM
Z_Stingray
May 27, 2008 07:34 PM
fraz00
Nov 19, 2007 10:34 AM
