Questions from a new HD owner
Old May 26, 2022 | 07:07 AM
TexasSasquatch's Avatar
TexasSasquatch
Default Questions from a new HD owner
So I just bought my first HD! Its a 2020 FLHP with 10k miles. Everything is stock RK except the slip ons which I just changed to make it sound more like a HD. As a new HD owner, I have some questions maybe yall can answer.
- Weight Limits - I've looked up GVWR etc but Ive heard of people going well over that. I am 6'6'' pretty close to 400 and my wife is about 250. Ive taken her for a small ride around the neighborhood with no issues, but would it be safe or possible to do longer distance normal riding? Im having a hard time figuring out if the weight limits in the owners manual are for liability, or for actual mechanical failure such as bending an axle or blowing tires and stuff.
- Service - How much $ do yall save doing the normal Oil/Transmission/Primary fluid changes yourself vs the dealer?
- Oil Cooler - Has anyone else noticed how loud the oil cooler is on the front of the bike is on the M8s? Or just me?
- KickStand - Anyone coming from other bikes feel like HD kickstands dont go out far enough? I always feel like I have to keep my foot on the stand to keep it extended all the way until I dismount and turn the handlebars all the way to the left. I feel like if i dont there is a possibility the bike will/could roll foward and the kickstand will come up and the bike will fall.
Thanks for yalls help
Old May 26, 2022 | 07:12 AM
eighteight's Avatar
eighteight
The locking device on the jiffy stand has been used for 86 years it works just fine
( yes, riders from other brands find it different at first )
Old May 26, 2022 | 07:14 AM
TexasSasquatch
locking device?
Old May 26, 2022 | 07:20 AM
Goose_NC's Avatar
Goose_NC
Originally Posted by TexasSasquatch
locking device?
Unless Harley changed the kickstand, there is a locking tab that slides into the mount that prevents the side stand from folding up. Perhaps removing the cover will allow you to see how it works, and raise your comfort level.
And I've know many folks like y'all who travel on motorcycles.
Old May 26, 2022 | 07:25 AM
TexasSasquatch
I just looked it up on youtube, thank you! I feel much better about it now! Thanks
Old May 26, 2022 | 07:29 AM
NorthWestern's Avatar
NorthWestern
You will get a lot more traffic, and possible answers if you post this in the Touring sub-forum, or even the Milwaukee 8 sub-forum
Old May 26, 2022 | 09:14 AM
maxxym's Avatar
maxxym
To answer your question about fluid changes. You can save some money doing it all yourself. It's not hard. I would say you can probably do it all for 1/3rd of a cost it would be at the dealer. Plus, you get to chose which fluid brands you want to use, vs. HD branded ones.
Old May 26, 2022 | 10:48 AM
slw210's Avatar
slw210
There is more to the services than fluid changes, so really depends on how you value your time and if you can actually do the entire service (not that it's a guaranty the dealer does a good job).
Complete 3 hole in the FXLR runs around $60 or less in filter and fluid, just engine oil and filter is around $40 for 4 quarts and filter depending on what I can get the oil for. Catch a sale and you could save a few $$$.
Old May 26, 2022 | 02:15 PM
Glenn Gorman's Avatar
Glenn Gorman
As Roadwarrior mentioned, there's a lot more to a service than changing the fluid.
Before I road my Fatboy from Nashville to Philly, I had the local dealer do a full service and tire change.
And then around the 1,100th mile i find that all of my gear is covered in oil. The transmission drain plug had fallen out. Luckily the nearest HD dealer was only 10 miles away. They actually stayed open a few minutes longer to take care of me.
Would I use the same local dealer again,, YES. They took care of me when I stopped in and told them about my experience. They also paid the receipt from the other dealer and made notes in their computer in case I have trouble with the transmission.
Glenn
Old May 26, 2022 | 02:37 PM
maxxym's Avatar
maxxym
But wait! Before you do ANYTHING... you have to answer one important question..
wHaT OiL BrAnD wIlL yOu UsE?
