Removing sticky pad residue
Old May 14, 2023 | 06:46 PM
DaveyFB's Avatar
DaveyFB
Also use Goo gone
Old May 14, 2023 | 06:52 PM
M Oclaf's Avatar
M Oclaf
I wouldn't use acetone ... Usually something like WD40 will do the trick ...Put some on a shop towel, soak the residue, gibe it a minute and then give it a rub
Can you clarify?
Old May 14, 2023 | 08:43 PM
MotoJockey's Avatar
MotoJockey
Originally Posted by m oclaf
can you clarify?
fap..........
Old May 15, 2023 | 11:48 AM
Uncle Larry's Avatar
Uncle Larry
Buzz will come along soon to elaborate on this
Old May 16, 2023 | 08:25 AM
Jetblack3's Avatar
Jetblack3
Ran into similar issue when I removed several decals from snowmobile, PB Blaster worked way better than WD-40 or alcohol.
Old May 21, 2023 | 08:20 AM
andnepo's Avatar
andnepo
I used Goo Gone, and it worked quite well. I had to soak for 10 minutes then reapplied several times but eventually it removed the glue.
Old May 21, 2023 | 12:07 PM
ClifWideGlide's Avatar
ClifWideGlide
At work we used this https://www.3m.com/3M/en_US/p/d/b40070712/ to get off the sticky residue from automotive trim and such. It works good but is expensive.
Old May 23, 2023 | 11:48 PM
NorthWestern's Avatar
NorthWestern
Another Goo Gone gel fan here. WD40 is good, too, since you are just talking about shooting it on the chrome
Old May 25, 2023 | 01:07 PM
Black Ultra's Avatar
Black Ultra
Brake clean works well also, particularly on chrome or glass. Leaves very little residue so it's easily cleaned up after.
maxxym
Detailing
39
Apr 9, 2022 07:36 AM
No Tyme
Aug 20, 2018 09:11 PM
dpk20x
Detailing
17
Dec 17, 2012 09:03 AM
Romark
Apr 6, 2009 05:47 PM
wnogood
Detailing
Apr 18, 2007 10:29 PM
