General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
While I'm no expert, I've played with fasteners and machining of stainless for a while.. Everything I've read says that 304/18-8 and 316 area about the same.. Composition is close but 316 had 10% nickel instead of 8.. It's more expensive, has better corrosion resistance than 304 / 303 but is pretty much the same for tensile and yield strength.. More like grade 5. Not sure you can boost 316 to grade 8. The big issue is that both can be work hardened. Depending on the manufacturing how the part is made can make a big difference in tensile/yield strength..
ARP, I think uses something close to A286 or 17-4 stainless but they claim to be using 300 series SS..
Yes, I believe you are right about the 316 strength. Was thinking about my days designing piping and using A/SA193-B8(304) and B8M (316) bolts. Not grade 8. Brain fart.
I have welded 17-4 before. I think ARP stainless bolts are something else. They look like a 300 series stainless to me. Polished up nice too
