lose docking system
Old Nov 30, 2023 | 09:35 AM
dmkress's Avatar
dmkress
2nd Gear
Default loose docking system
I have a 2021 street with a tour pack attached with a docking system. It has developed some slop and bounces up and down some. It is enough that people following me have mentioned it. Is there an after market locking parts to replace the Harley ones. I would not mind even removing a bolt or two when installing and removing my tour pack, as it is not done that often. With the rough roads we all have to deal with, I think it will just continue to get worse. thanks Dan
Old Nov 30, 2023 | 10:19 AM
BrandonSmith's Avatar
BrandonSmith
First things first, did you rotate the rubber on the dock? Those four rubbers are elliptical (football) in shape. You rotate them to a tighter spot so the tour pack doesn't bounce.
If they are worn out, replace them.
If the docking hardware is aftermarket, the rubbers are probably not elliptical.
Beyond that, did you tighten the bolts that pass through the locking mechanism on the tour pack bracket?
If so, lift up your tour pack and set it down a few times while you're looking at the bolt. Does the nut/bolt wiggle around?
If so, the issue is not the docking hardware, the bolt is not clamping the locking mechanism enough to hold it tight to the tour pack bracket. You can add a thin washer under the bolt head so you get stronger clamping force, to prevent the nut & bolt from wiggling around.
Old Nov 30, 2023 | 10:26 AM
Pappy35's Avatar
Pappy35
I just fixed the same issue by ordering the fixed mounts (with chrome trim) off one of the Limited's. Total cost was "just" $246, with the chrome trim it's around $175. The whole thing comes off by removing the four bolts that fix the mount to the frame. It's very easy. Another plus is you can easily reach the two forward nuts under the Tour Pak should you want to remove it and leave the frame attached. I never take the Tour Pak off except to clean the bike, but when I do, I find it easier to line it up to reattach it to the bike.
Mount: 53000125 Trim: 47200080 and 47200081 Trim Mount Screws: 10200155 x 8 Rack Mount Bolts: 3684 x 4 (or any 5/16-18)
NCPiper's Avatar
NCPiper
What BrandonSmith said.
Those 'cams' can be rotated to adjust the tightness. It probably is loose and needs to be tightened and positioned correctly.
Old Nov 30, 2023 | 11:38 AM
dmkress's Avatar
dmkress
2nd Gear
Thanks for the info. will try rotating the mounts.
Old Nov 30, 2023 | 11:41 AM
dmkress's Avatar
dmkress
2nd Gear
pappy35, thanks for your insight. and thanks for including the part numbers. Very felpfull.
Old Nov 30, 2023 | 02:32 PM
NCPiper's Avatar
NCPiper
I see those mounts practically being given away. As a matter of fact, there's one now for sale in my area for $25.00
Screamindaemon
Sep 20, 2020 05:10 PM
leftyjm
Jul 12, 2017 04:56 PM
Just Me
2014-2024 Touring Models
Sep 30, 2015 11:17 AM
Crusher
Nov 5, 2010 11:38 AM
Big_Al47
Oct 1, 2010 12:24 PM
