Pump?
Old Jan 13, 2024 | 05:35 PM
McGurk's Avatar
McGurk
Default Pump?
I firmly seated Super E accel. pump but I get (0) stumble, in fact it performs better. Should I be concerned? Idles fine, revs fine, ride fine.
Old Jan 14, 2024 | 09:01 AM
TexasScooterTrash's Avatar
TexasScooterTrash
OK, so what's the problem? If it's not broke . . . don't fix it.
Old Jan 14, 2024 | 11:49 AM
McGurk's Avatar
McGurk
I'm wondering should I be concerned that my motor requires the pump be seated? Doesn't it usually require at least 1/2 0 1 full turn out?
Old Jan 14, 2024 | 08:08 PM
Max Headflow's Avatar
Max Headflow
No puffs of black smoke out the exhaust?
Are you a throttle whacker?
Old Jan 15, 2024 | 05:04 AM
McGurk's Avatar
McGurk
No 2 both
Old Jan 15, 2024 | 09:35 AM
Max Headflow
I'll agree with Texas. It's probably OK. Screwing in turns the screw turns down pump. You probably still have a little bit of travel on the pump with the screw seated. You might be running a little rich on the intermediate but I wouldn't mess with it unless you are getting real crappy gas mileage.
Old Jan 15, 2024 | 01:09 PM
60Gunner's Avatar
60Gunner
I'm not real familiar tuning the Super E. I DO know when tuning a mikuni hsr series carb, which has 2 adjustments for the accel. pump, I always turn both down/off when tuning the jets. It will interfere with the tuning process really. Then the pump, where it comes on and starts squirting fuel and for how long is adjusted to give extra fuel as needed when the wick is twisted hard. It will run perfectly fine without the pump but might stumble when you accelerate hard and fast.
Hope this helps understand the reason for the pump basically.
Old Jan 15, 2024 | 02:00 PM
Max Headflow
In HSR carbs there is a standard 3rd adjustment.. Jet size.
Old Jan 15, 2024 | 02:05 PM
Max Headflow
On a SnS super G/E the only adjustment is length of stroke of the pump. I guess one could change starting time with a different length pump pushrod.
Old Jan 15, 2024 | 09:27 PM
McGurk's Avatar
McGurk
It IS getting horrible gas mileage. My guess would be the idle jet (S&S Super E) is too rich?
