Torque wrench??
Old Mar 13, 2024 | 07:52 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Originally Posted by 81shovelhd!
Around 36 years riding and whatever repairs/adjustments I've ever done have been done without a torque wrench.
Then again, I've never done a rebuild or any serious internal work
Nothings ever cracked, busted or fallen off.
Am I alone in this?
I'm about to install rear shocks on my 2010 RK to replace the originals and the torque wrench came to mind........thinking of getting one for this operation.
​​​So........to what extent are torque specs necessary?
And can you recommend one?
Tx!
Originally Posted by Rounders
If think you are mistaking the spirit of this thread. He really doesn't want to buy tq wrenches.
Reading comprehension is a virtue. Forgot to put my disclaimer on my post - now added.
Maybe read, think, and digest the OP spirit of the thread before spouting out more of your gibberish.
The OP asked a question and requested a recommendation.
Quit trying to derail yet another thread. Here is your patch, wear it with pride; now go back to your 103 build if you can find all the parts in your garage.
Old Mar 13, 2024 | 08:39 PM
Old New Rider's Avatar
Old New Rider
Originally Posted by GalvTexGuy
I’m big on torque wrenches and Loctite when it comes to critical fasteners on my motorcycles.
I use CDI torque wrenches.
+1
Old Mar 14, 2024 | 12:23 AM
07UltraGuy's Avatar
07UltraGuy
I'll interject something to chew on...
Professionally, I have managed a QC department with a ton of calibrated equipment, including calipers & torque wrenches, etc. so I understand the need for ensuring the accuracy of the tool.
At home, I have a couple of tq wrenches. They're inexpensive versions that you'd expect to find in many a DIY-type of garage.
One of them had a certification when it was new, but I've never sent it in in maybe 10 years of occasional use, but I still trust it to be accurate enough.
Again, for rebuilding critical components, accuracy is important, or failure can certainly result.
So how often do you guys calibrate them, if ever?
BTW I'm still trying to figure out why a guy who by his own admission has never used a torque wrench on his axle nuts, is suddenly thinking of buying one to install rear shocks.
No offense meant to the OP, it just struck me as an odd project to "require" a tq wrench after so long of not using one at all.
Old Mar 14, 2024 | 04:44 AM
TracerBullet's Avatar
TracerBullet
same
Old Mar 14, 2024 | 04:51 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
Tx!
I don't do much wrenching on a daily basis so no practice between services on doing up fasteners.
I ended up buying 2 to cover all the small to medium jobs so far but will need to get a "big" wrench if I ever have to remove the engine sprocket. For now I have one good enough for the 100 ft-lbs axle nuts.
All three are made by Norbar.
Old Mar 14, 2024 | 05:08 AM
Gas Smasher's Avatar
Gas Smasher
I am big on torque wrenches too. I torque almost everything. Sometimes the service manual calls out anti-seize on the threads, sometimes engine oil, sometimes Loctite. I generally follow the manual. If it doesn't specify anything most of those get blue Loctite for me. Most people don't realize that the majority of fasteners get far overtightened when done by feel, which can be just as bad as not tight enough.
I was a professional mechanic most of my career before moving into the management ranks. I have Snap-On torque wrenches, which are mostly made by CDI. All of mine are CDI. They make a good wrench.
Old Mar 14, 2024 | 05:17 AM
Spartanden's Avatar
Spartanden
You could also go to auto parts store and rent one for your project. I recommend buying one, but if you do not plan to use but once or twice, rent one. And yeah, I got 1/2, 3/8, & 1/4 drive torque wrenches
Old Mar 14, 2024 | 07:31 AM
Old New Rider
I think it's the other way around - Snap On makes the torque head of CDI, and a Taiwan firm makes the handle to save money over the all Snap On wrench. Regardless, CDI is a fine torque wrench for the home owner that isn't torquing all day, every day like a professional shop does.
Old Mar 14, 2024 | 08:33 AM
470004's Avatar
470004
I still using Craftsman's torque wrenches when they were made in the U.S.A.
Old Mar 14, 2024 | 05:28 PM
Uncle Larry's Avatar
Uncle Larry
Am I alone in this?
Tx!
Who is making the mistake ?
