reverse issue
Old Mar 15, 2024 | 08:54 PM
jimkamiah2012's Avatar
jimkamiah2012
Stage IV
Default reverse issue
Hello everyone, I have 2012 TriGlide, Reverse stopped working. Changed the starter/reverse motor, solenoid, waiting on a new circuit breaker (breaker never popped) just trying everything. Start the bike. push the on button for reverse. Light comes on. Push the reverse switch and nothing happens after doing all that. It seems like it is not getting electricity to the reverse motor. Battery is checking good. While under load it is putting out good voltage up to 14 v. Does anyone have an idea to where I should look next. This has been driving me crazy. It is a 2012 but has only 15000 miles. Thanks in advance
Old Mar 15, 2024 | 08:56 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Start looking with by doing a DIAGNOSTIC SCAN FOR ERROR CODES.
Old Mar 15, 2024 | 09:07 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
It seems?
It is either getting power or not getting power. A voltmeter will tell you if the motor is getting power.
How did you determine the battery is good?
Are you working with a wiring diagram?
Old Mar 15, 2024 | 09:08 PM
Max Headflow's Avatar
Max Headflow
Instead of shotgunning everything, get a test light and check the control signals on the solenoid and the relay if there is one..
Old Mar 15, 2024 | 09:37 PM
jimkamiah2012
Stage IV
Thanks Texas. Got a b1155 code neutral short to battery. Now I guess I will have to find it. I am not that great with electrical stuff. Got any ideas ????
Old Mar 15, 2024 | 09:43 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The first thing you need is the Trike Supplement to the Servce Manual.
It will explain the chain of events that must take place in order for the motor to be energized.
The reverse circuitry on a Tri Glide is pretty complicated.
Old Mar 15, 2024 | 09:45 PM
jimkamiah2012
Stage IV
I rode the bike and had the battery checked. With bike not started it was 12v and then started it was 13 to 14v and under load it was still 12 to 13 v
Old Mar 15, 2024 | 09:48 PM
jimkamiah2012
Stage IV
It is just weird. I live in Idaho and at the end of last riding season it started to act up ( sluggish if you will ) now it just won't work ugh. Might just have to take it to harley, that's gonna hurt $$$$$$$ Thank you for responding
Old Mar 15, 2024 | 10:55 PM
Max Headflow
Here is the reverse section off of HD..
Check to see if you have voltage across the 2 wires.. You may want to raise the wheels off the ground when doing the test.. BTW, If neutral light acting funny, you'll need to fix it.
Tarheel2288
Jun 12, 2021 07:51 PM
ChasNZ
Feb 4, 2016 07:19 AM
chopped7
Apr 25, 2015 09:49 AM
JT-FXDL
Sep 7, 2012 10:53 PM
1911shooter
Shovelhead
May 29, 2007 03:23 AM
