New Member - 83 starter problem
Old May 14, 2006 | 12:09 PM
1911shooter's Avatar
1911shooter
Default New Member - 83 starter problem
Hello everyone new to this forum but a longtime Shovelhead owner! Anyway looks like some good info here! ANyway I have a 83 FXSB with a starting problem. When I push the starting switch I get a "click" from the starter solonoid and the starting motor does not spin. This is intermittant however and sometimes it will engage and turn over the motor just fine. The "Bosch" starter relay seems to be working ok and when I remove the relay and jump the relay socket pins (to eliminate the relay as a problem) it does the same thing. NOW when I pop the rubber cover off the solonoid and jump the relay connection stud to the battery cable stud it slams in with authority and spins the motor like new. Any ideas or am just being lazy at looking for an old fashioned bad connection somwhere between the relay and the starter? Thanks!
Old May 14, 2006 | 10:21 PM
pococj's Avatar
pococj
Default RE: New Member - 83 starter problem
Often the contacts in the solenoid start going bad, but directly jumping them will still make 'em work OK. Eventually, they'll get bad enough to not work at all, and then you get to push start the ol' gal. You could ask me how I know this, but I'd just lie to ya, and tell ya I heard about it!
It appears you've eliminated the relay as the culprit since it fails when you jump the relay . I'd buy a solenoid rebuild kit, or just cop a new solenoid. Stay away from the cheap imports, and spend the dinero on an Accel unit.
And being the tinkerer that I am, I usually eliminate the relay altogether. I install a good quality toggle switch and run a wire from the large battery terminal on the solenoid, to an inline fuse, to the toggle switch, and back to the small terminal on the solenoid. (Actually, I hardly ever stick the fuse in the circuit, but I thought it'd be better to throw that in, just in case someone tries it and has something short out. Kinda like, "Do as I say, not as I do" thing. )
Old May 15, 2006 | 01:45 PM
1911shooter
Hey thanks for the reply but I think I have found the problem - nothing more than needing a new battery! Spins like new now - funny thing is it would not necessairly work when jumped with a shop battery - which could be bad also and jumper cables are not the tightest connection. I like the toggle switch idea of yours. I have considered the idea of eliminating the starter switch and relay altogether and wiring a heavy duty momentary contact switch from the small relay stud on the solonoid to the + battery side with some 10 ga. wire and making a nice stainless mount for the switch below the ignition switch. Either way I think I mostly eliminated the problem with the new battery.
Old May 15, 2006 | 10:24 PM
pococj's Avatar
pococj
I hate dead batteries!
Old Jun 11, 2006 | 01:01 PM
dracos's Avatar
dracos
I have an '83 FXSB also. Exactly the same problem. When I hit the starter button it just clicks. I have been riding this bike for 18 years now and it has done this the whole time. Have had new batteries, new solenoids, new starters and everything else. When I push the starter button and bump the kickstarter, it spins right over. Just got used to doing that and don't even think about it anymore.
Old Jun 11, 2006 | 02:30 PM
1911shooter
No doubt an aggravating problem. A new battery seems to have corrected the problem - maybe 99% - but the other day it "almost" did it again - it clicked momentairly and then the solonoid engaged. As I mentioned before when I jump the solonoid it engages just fine which to me indicates a voltage drop or other resistance somewhere in the starting circut. I may live with this for the summer but then in the winter tear into it and replace all starting circut wires with new, heavier wiring. Also I am not particularly fond of the way the solonoid is built. I took a bad one apart and could see where several improvements could be made and may experiment with machining a better contact plate for the solonoid as this is a problem area and the existing contact burns badly.
Old May 27, 2007 | 11:02 PM
glidezilla's Avatar
glidezilla
how do you bypass the relay? having same problem on 04 electra glide
Old May 29, 2007 | 03:23 AM
jmetro's Avatar
jmetro
here's a little known fix. if you've tried everything else by way of the starting system, check your ignition timing. dont static time it, do it dynamically ie. with a timing light. i know it sounds insane, but i have fixed many a starting prob on shovels and very early evo's by just correctly timing the ignition. *my shovel starts on the first rotation*
laserman2431
Jul 30, 2018 09:28 PM
Jokr99
Jun 29, 2012 06:13 PM
kokopelli372
General Topics/Tech Tips
Dec 17, 2009 08:51 AM
andrewb648
Jul 30, 2009 09:25 PM
TBone2
Shovelhead
Aug 22, 2006 08:25 AM
