General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
2005 FLHTCI here... wondering what folks are using for a Wheel Cleaning Stand for their bike? Basically, I want to roll my wheel/s on dolly so I can rotate it to clean.
I believe the bike weight is roughly 776-820#'s. Not sure what it would be at each wheel. I used a neighbor's stand and it was a Grand Pit Stop brand which held less than 485#, so That is out of the question.
What is out there; what are u folks using that will hold the weight and turn with "ease"?
thnx.
I have one of those roller stands from J&P, does not work as planned. Because you have your bike on the jiffy stand, the wheel is not straight and it walks off to one side of the rollers. I used it a couple of times then decided it was more of a PITA then just rolling the bike forward.
If the bikes already up on the jack I'll clean the wheels while it's up but I go typically use the roll forward or backwards depending upon my mood that day. The back wheel can be tough to get in one move but it's possible if I bend my fat *** over enough. I think those rollers are intended for bikes that have a center stand...maybe.
Sorry ppl, forgot to mention my bike has a sidecar, so bike is straight.
I do roll the bike forward/back when working on wheels but the dolly seems much more easier. Like I said, I used neighbors but it just didnt hold the weight on rear wheel. Too hard to spin.
I guess I can use a bike jack just enough to lift wheel/s off ground. The Dolly just seemed simple and smarter to use.
thnx for all the replies!
