Hand Numbness?
Old Oct 10, 2007 | 11:10 AM
tucdog's Avatar
tucdog
Stage III
Default RE: Hand Numbness?
I had the same thing with stock grips...they were just too small for my hands. That and easy up on the grip pressure did it for me.
Old Oct 10, 2007 | 03:45 PM
zuma's Avatar
zuma
Iam changing grips by Monday to the Kuryakyn, I will let you know how I makee out.
Thanx
zuma
Old Oct 10, 2007 | 06:01 PM
bobcowan's Avatar
bobcowan
The most common cause of hand numbness is compression of the median nerve in the carpel tunnel. The answer is actually pretty simple, and it's free.
Ergonomics.
Since you have short low drag bars, I would guess that you're leaning on the hand grips. Unless you have extra long gorilla arms. The natural position that people fall in to is to extend the wrists and lean on the palms of the hands.
Imagine that you have a ruler strapped to the back of your arm that extends past the knuckles. Never let your knuckles touch the ruler.
If that becomes uncomfortable, you might consider new bars that place your hands in a more favorable postition.
Old Oct 10, 2007 | 07:47 PM
zuma's Avatar
zuma
Thanks Bob, I will try that as well, just like the keyboard...
zuma
Old Oct 10, 2007 | 07:51 PM
ironhorselady's Avatar
ironhorselady
ORIGINAL: anubisss
Try a throttle rocker if the loosening of the grip doesn't help...
Ditto.That took care of itfor me.
Old Oct 10, 2007 | 08:59 PM
zuma's Avatar
zuma
I saw that, is it hard to get use to? I assume you palm heel the throttle?
Nice mtn pics, is that VA or WVA?
Thanks
Old Oct 10, 2007 | 09:08 PM
ironhorselady
It took about 3 minutes to get use to-can't imagine riding long days without it. Yep-fits right into your palm. You can ride and stretch your hand wide open, use your thumb for awhile to switch position, etc.
Thanks. . .home. . .Virginia. . .
Old Oct 10, 2007 | 09:48 PM
clutchglass's Avatar
clutchglass
Anubisss is right on with the throttle rocker for long trips anyway. Also, Kuryakyn (not sure if I spelled it right) makes some grips called iso grips. I have some on my softy & they made a BIG difference. Stock grips & stock seats suck.
-clutch-
Old Oct 16, 2007 | 02:05 PM
ken thompson's Avatar
ken thompson
The Schlong Man
If you are new to riding then this is something that happens that you'll need to deal with for a while. Eventually you will get used to riding more. You will become more comfortable and the numbness will go away. When I first started riding not too long ago my fingers would go numb, then my hand, then my whole arm. very disconcerting. It gradually becomes less and less and now I just get a little tingle in a couple of fingeres every now and then. Shakes right out.
Old Oct 16, 2007 | 03:45 PM
08CVORK's Avatar
08CVORK
Ken, I hate to tell you this but your left leg is broken.
