Speedometer Problems
Old Oct 5, 2007 | 03:50 AM
masu's Avatar
masu
Stage IV
Default Speedometer Problems
Aloha,
I have a 1987 FXRC and the Speedometer stopped working. Any one know of a good way of determining which component died? Speedo, Cable, or Drive Unit? Also a recommendation of a site to get replacement parts?
Thanks.
Masu
Old Oct 5, 2007 | 07:37 AM
glide's Avatar
glide
Default RE: Speedometer Problems
Usually it's the cable that goes, disconnect it and pull the center out and you'll probably see a piece broken.
https://www.zanottimotor.com/shopping/pLookUp.php
Is good for 20% off usually.
Old Oct 11, 2007 | 03:49 AM
masu's Avatar
masu
Stage IV
Unfortunately for me, it's not the cable but the drive unit. Looks like I'll have to borrow someone's lift and work on the front end. I guess it's a good time to replace the pads too.[8D] Thanks for the help.
Old Oct 11, 2007 | 07:34 AM
glide's Avatar
glide
Check on the wheel side of the drive unit. There's a tab that has to fit in a slot in the wheel so it can turn the gears in the drive unit and if it comes out of the slot, it will bend and not turn the unit. May be a simple solution.
Old Oct 18, 2007 | 03:35 AM
masu's Avatar
masu
Stage IV
Thanks for the tip. In order to check that tab out, do I need to remove the wheel?
wrenchman9
Ironhead
May 18, 2015 06:45 AM
Stampy167
EVO
Apr 6, 2015 03:05 PM
Sissy24
Shovelhead
Sep 2, 2014 06:04 PM
berndog
Shovelhead
Jul 3, 2012 12:56 PM
average_hog
Feb 24, 2010 11:07 PM
