forward controls back to mid controls question
Old Jan 7, 2006 | 01:17 PM
83fxrt's Avatar
83fxrt
Stage II
Default forward controls back to mid controls question
Does the inner + outer primary covers have to come off to install the shift shaft. Havent got parts yet and im not sure if the shift shaft is welded or if shaft comes off linkage. Thanks
Old Jan 7, 2006 | 03:56 PM
Dan B's Avatar
Dan B
Default RE: forward controls back to mid controls question
If you got a -06 and want to install the taller shift shaft that comes with the kit for -06 bikes, yes, then you have to remove inner and outer chaincase (and the clutch and some other goodies) in order to do this. You can still use the original lower shifter shaft, but then you have to bolt the midshaft to the cylinder. If you remove the inner and outer, you can discard the midshaft.
/Dan B
SuperSport66
Mar 31, 2013 10:26 AM
mizmazzle
Mar 3, 2011 08:18 PM
OhioSkully
May 9, 2008 07:10 AM
mdog2222
Apr 10, 2007 02:00 AM
fireball
Apr 7, 2006 08:04 PM
