Air Temp Guage
Thanks,
RJ
All you need is about 16" of 14 gauge wire and some double-stick tape. Remove fairing... find the sensor (it's a white square thingy about 1.25" square mounted pretty much in plain sight). Unclip it from where it's mounted and then splice in the 16" of wire mentioned above...
Drop the sensor down out the bottom of the fairing and use some double stick tape to fix it to the chrome facia plate below the fairing/behind the headlight area.This iswhere it's out of the way and not visible yet is in the open air and will give you a good reading.
Easy to do and when done it's pretty accurate and useable compared to how it is from the factory.
