Check Engine Light
Old Aug 20, 2008 | 11:42 AM
famed02's Avatar
famed02
Stage I
Default Check Engine Light
I installed a Hyper Charger and a RUN/TURN/BRAKE module on my 08 softail. Now, after i turn on my bike and the fuel has been primed, my check engine light comes on for about 3 seconds then shuts off. I have checked the dtc codes and there are none. It does appear that it gives me "pn" numbers such as "pn 67003-08".
Can someone please tell me what is up? I figured maybe it was the run turn brake that is messing with something.
Here is the biggie, I have a buddy who's bike does it as well. 05 roadking, however, his fuel gauge is acting wierd because when they took the tank to paint it, it didn't go on right and got the fuel level thing stuck inside and now the gas gauge reads full at all times.
Is this the bikes way of saying some part is messed up? Its driving me crazy! Any advise?
Thanks in advance
Old Sep 5, 2008 | 12:28 AM
GT_RoadGlide's Avatar
GT_RoadGlide
Part number 67003-86 (a,b,c,e) is for the instrument cluster. I'll check my 07 service manual to see if it has anything.
Old Sep 5, 2008 | 12:52 AM
GT_RoadGlide
Normal operation for an 07 RG is "When the ignition switch is turned on, the check engine lamp will illuminate for approximately four seconds and then turn off." Sounds like normal operation.
Old Sep 5, 2008 | 03:13 AM
ayebyte's Avatar
ayebyte
I realize the engine light comes on while the fuel pump is kicking in and that you should wait until it goes out to fire it up. Sometime it comes back on for a few seconds up to a few minutes. I called the service dept. and they told me to check my coil wires. They said as long as it goes out ..."NORMAL"
myrtle2008
Jan 16, 2013 08:01 PM
markkoby
Exhaust System Topics
Feb 13, 2012 01:34 AM
WNMORE
Jul 17, 2010 11:39 PM
Jock
Apr 27, 2008 01:20 AM
dr.phatkins
Apr 9, 2007 11:01 PM
