stripped button head
Old Oct 26, 2008 | 04:14 AM
mopardave's Avatar
mopardave
Sounds good! Glad it worked out for ya.
Old Dec 25, 2008 | 01:58 PM
mencken's Avatar
mencken
Stage I
Stop Stop Stop. Do NOT drill out the screw as you would for an easy-out; it's too small, and you'll end up boogering up the hole. Instead, all you want to do is drill the HEAD off the screw by drilling a small, shallow hole in the middle, then widen it with a larger bit, etc. When the head pops off, there'll be enough of the screw left protruding for you to grab it with pliers and turn it out. I just did this; it works.
Old Dec 25, 2008 | 03:30 PM
cfdcaptain99's Avatar
cfdcaptain99
Default +1
I agree... the screw is already ruined. With a button head cap screw, the stripped out hex area gives you a great pilot hole to help center the bit. Take a drill bit one size larger than the thread diameter (a #10 screw has a 3/16" diameter). Drill carefully until the head of the screw pops off. Once the part in question is removed, simply turn out the threaded shank with a pair of pliers.
ralfie
Apr 5, 2014 09:33 PM
Rickr01
Dec 2, 2013 04:09 PM
Aaronbagby
May 9, 2013 09:24 PM
rojuwi
Oct 26, 2012 10:53 AM
ashmarc
Jul 18, 2010 10:05 AM
