General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Hey everyone,
I'm putting on a jiffy stand extension and ruined several drill bits in the process. I tried bits for tempered steel and doesn't do a thing! Am I looking at dropping $12 on a diamond tip for this? Thanks
Is the problem that you can't drill through the chrome finish, on the jiffy stand? When I need to drill through something that is chrome plated, I use my dremil (high speed drill) with a sanding disc or grinder attachment. I only grind as big a spot as necessary, so I can start my drill bit on bare metal.
Tom
Didn't have a problem drilling a pilot 1/8" to start. The ext. requires a 1/4" hole so I just thru the bit in and nothing, brand new tempered steel bit too! It scorched the tip like it couldn't cut?
Yea, but I already got it started and like to finish it myself. Are there harder bits that can be used?
Yes,carbide.
Being a machinist i have drilled many holes.
I think the problem you are having is chatter and the drill motor and jiffy stand is not rigid enough causing the drill bit to bounce.
Of course the stand is probly forged so it would be tough to drill in the first place.This why i suggested to have a machine shop do it for you.
A carbide bit is expensive and can break very easily when not used properly.
If you want to try it again,i would suggest using a HSS/cobalt drill bit and slow rpm.
Yes,carbide.
What he said. As a machinist, I do not suggest a carbide drill in a hand drill. Slow RPM & lots of oil to get it started. Do not be too proud to take it off and have a machinist buddy do it for you, one slip and you will be really piissed! Even just a drill press is better rhan a hand drill.
I'm sure there are machinists on here that would love to help.
