Replacing Harley covers
Old May 22, 2005 | 10:41 AM
rbeaston1's Avatar
rbeaston1
Stage I
Default Replacing Harley covers
I purchased Harley chrome themed covers for my air filter, timing cover, and Derby cover for my 2003 Hertiage classic . When I went to remove the stock covers, I had a problems with screws stripping and breaking. I used tools that I purchased from my local Harley dealer. Is this a common problem with the "lock tight" installation at the factories? Will Harley Corporate cover the cost of re-tooling?
Old May 22, 2005 | 06:50 PM
Pelonz's Avatar
Pelonz
Default RE: Replacing Harley covers
I've never had an issue with breaking stuff on my scooots when taking em apart. As for the motor co helping you , doubt it. Maybe you should pay someone to do the work next time.
Old May 23, 2005 | 06:26 AM
mikeisglidn's Avatar
mikeisglidn
its the price we have to pay to have purdy screws on our rides, ie hex heads torques, ect. they are a pain in the ***!
Old May 23, 2005 | 10:28 AM
pilot1996's Avatar
pilot1996
Couple of weeks ago when I was in the HD shop, I asked the head mechanic what the difference between red and blue loctite was. After explaining it, he told me about how difficult it is to get the screws out of the motor. He said he has had to help more than one guy who broke off a screw head or stripped it when taking out screws that were put it in with loctite.
What I got out of it was, be very careful and meticulous when working these screws, and make sure the size of the wrench/allen/hex tool that I'm working with is exactly the right size.
Mac
Old May 23, 2005 | 11:08 AM
jcc/tx's Avatar
jcc/tx
I've had trouble with the aircleaner cover screws on both my Sporty and my 'Glide. The Sporty screwa froze and turned the nuts in the plastic backplate (major hassle); the 'Glide twisted one of the inner fillter screws off (had to drill and re tap). This is obviously a poor design area for HD. The one that twisted off was a very poor grade of screw (compressed buffalo dung, I think??).
Old May 23, 2005 | 02:56 PM
AceArt's Avatar
AceArt
ORIGINAL: pilot1996
Mac
What is the dif,. Mac? I forget. 10-4 on the screws. Went to take off my backrest the other day and didn't look closely enuff. Used a hex instead of a torx and stripped the inside of the screw. Fortunately there was a bolt on the back which was accessible, so no big prob., but it sure is easy to do.
Art
Old May 23, 2005 | 05:27 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Broke off a footpeg once trying to twist it off but have helped several friends change covers this year (you know how those new guys always want to change covers) and had no problem.. I used a 3/8 socket wrench (that gives you more leverage without slipping out).
Terry
Old May 23, 2005 | 08:34 PM
Tripper's Avatar
Tripper
Blue loctite = soft hold
Red loctite = hard hold
Old May 23, 2005 | 08:35 PM
jeepwatchman's Avatar
jeepwatchman
If I remember right, the red is more of a permanent locktite while the blue is made so it can be loosened. Basically, the red stuff is a bear to break loose.
Old May 23, 2005 | 09:46 PM
pococj's Avatar
pococj
ORIGINAL: jeepwatchman
Use heat on the red when you want to remove it.
bitmonx
Feb 14, 2019 06:31 AM
Kojax
Jan 23, 2016 11:39 AM
jpbutler1983
Apr 23, 2015 02:18 PM
brgtr3
General Topics/Tech Tips
Mar 5, 2011 11:33 PM
LOWRIDER95
Apr 12, 2006 07:45 PM
