display screen all orange????
Old Sep 25, 2010 | 08:55 AM
charliescham's Avatar
charliescham
Stage I
Default display screen all orange????
flhtcu 07 my display screen faded and now finally all orange everything seems to work just can see screen ?? where do i start
Old Sep 26, 2010 | 05:32 PM
dmercy's Avatar
dmercy
Guessing: I believe there is a connector on the back of the radio unit. Try pulling the power connector from the unit and then reinstall it. Probably best to remove seat and disconnect battery first! If the display contrast comes back, it was just a loose connector. If the contrast does not come back after doing this, well, it probably needs looking at. If it does not come back, I don't know if just the display can be replaced.
Old Sep 27, 2010 | 12:57 PM
flynng's Avatar
flynng
Toggle through the choices till you get to the display setting then try adjusting contrast. Maybe you already did that.
Old Oct 26, 2010 | 01:48 PM
scuba335's Avatar
scuba335
3rd Gear
had the same problem on my RG sent it to Iron Cross Audio. They told me it was a bad display
Old Oct 26, 2010 | 11:53 PM
FLHTom1948's Avatar
FLHTom1948
@dmercy: good advice; but "to hell with luck; god bless", i believe you make your own luck, in other words, you are responsible for what you do...
Mike-81
Audio Systems
21
Jun 3, 2019 03:29 PM
Sc0-
Audio Systems
Oct 11, 2015 09:46 PM
BuzzL
Sep 12, 2015 07:06 PM
Afishinado
Oct 1, 2013 10:16 AM
Wanna Ride
Aug 4, 2010 12:17 AM
