Screaming Eagle Cams
Old Nov 11, 2003 | 09:29 PM
Doc T's Avatar
Doc T
Stage I
Default Screaming Eagle Cams
<FONT face="Arial, Helvetica, sans-serif" color=black size=3>Howdy,</FONT></P>
<FONT face=Arial size=3></FONT></P>
<FONT face=Arial size=3>Has any one had any experience using a HD SE 251 cam in conjunction with a 95 CI with sreaming eagle heads. Also has any one used a SE 211 cam with this setup?</FONT></P>
<FONT face=Arial size=3>Thanks</FONT></P>
Old Jan 14, 2004 | 10:56 AM
ross's Avatar
ross
Stage III
This Forum Is a very good idea ,and has great questions.One big problem No answers You wouid think with Harley name on the web site someone would be helpful. I answer all I can but only have questoins.I am working on the same thing you are with my 95 inch &gt;/I was told the 211 was a good cam ,and would fit with factory, push rod.If Harley doesn,t want to heip I would look at after market cams gear drive
Old Nov 10, 2007 | 07:44 PM
robertjoe's Avatar
robertjoe
Stage I
Default RE: Screaming Eagle Cams
Doc T
I have a 06 Road King 95" kit Screanin Eagle ported htcc heads and pistons, 50MM T/B, 251 cams, V/H pro pipes, race tunerand had the bike Dyno at 100 H/P 95 lbs Trq Still not happy so I might go to a little more cam just not sure which one. I'm changing the compensating sprocket to 21 tooth and changing exhayst to RB racing 2 into 1 Let me know what you think.
Bob
Old Nov 10, 2007 | 07:48 PM
Harleypingman's Avatar
Harleypingman
robertjoe: With the 21 tooth compensating sprocket you will be turning about 4,000 rpm at 70 mph. A less penalizing set-up for keeping the rpms down would be a 3.37:1; 24 tooth compensating sprocket and 36 tooth clutch sprocket; $450 list price for the parts from HD.
ohiobuck
May 10, 2022 08:35 PM
Taylorized
Feb 15, 2010 04:56 PM
FiremanJeff
Touring Parts
Nov 29, 2009 10:28 AM
capt42a
Exhaust System Topics
22
Mar 1, 2009 06:46 PM
steveinsac
Jan 28, 2008 06:03 PM
