General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I have a 1990 elsctra glide classic, when i go to start i get a clicking noise and no start even with a new fully charged battery, and it won't take a jump.Please help is it just my relay, is it a solenoid, if so can i just replace the solenoid. or is it the starter?
If you want to fix this problem yourself, this is what you do.First, remove your ground cable on the battery, you don't want the motor turning over when you do this, it'll make you hurt yourself getting your hand out of there. Remove the three screws on the solenoid cover and the cover itself. Pull the plunger out. Take a file and clean the corrosion from the brass end of the plunger and reinstall.
