Stuck torx bolt removal
Old Jul 8, 2012 | 11:09 AM
vangasman's Avatar
vangasman
If you do strip it cut a slot with a dremel and use the hand impact, have gotten many out this way.
Old Jul 9, 2012 | 06:31 AM
flhxi9914's Avatar
flhxi9914
6th Gear
thank you very much appreciated
Old Jul 9, 2012 | 07:04 AM
Ventana's Avatar
Ventana
On this particular bolt I don't think I can get a dremel in there to cut a slot. It's the bolt that holds the rear brake arm assembly on the forward controls. It's a long recessed bolt.
What surprised me was how tight it was after only being on there about a min or two. I know it's not cross threaded, I started it by hand and only finished it with torque wench.
Old Jul 10, 2012 | 04:36 PM
clovisrider's Avatar
clovisrider
You can use a soldering gun. Just keep the tip of the gun against the center of the screw till good and hot. The heat will loosen the loctite. It may discolor the finish, but you can always replace the fastener. Much easier to replace than to try and get out a damaged one.
Old Jul 10, 2012 | 08:07 PM
Chuck1's Avatar
Chuck1
Most torx bolts I won't even attempt to loosen without wacking them with a little impact wrench and new bit. Never had a problem since.
82flh
Apr 20, 2017 09:10 PM
surfrat2
Feb 3, 2013 12:38 PM
bigpercentcountry
Mar 7, 2011 08:46 PM
Tri Glide
Aug 29, 2010 05:56 PM
Shift_4lo
Jan 12, 2006 12:18 AM
