192 flh electraglide.....throttle cable problem
Old Oct 14, 2012 | 10:17 PM
met's Avatar
met
Default 192 flh electraglide.....throttle cable problem
hi,
not sure if anyone has had this problem, but here goes.
i have a 1972 original harley FLH.
it has a spiral type throttle cable that goes inside the handlebar and down to the carbie.
since i've owned the bike, the throttle cable has always been stiff, scratchy, etc. to the point that the throttle does not return back as it should.
i have taken it out and lubricated it both the wire and the outer metal housing and although its a little better, its still stiff to the point it wont return back to the right place on the handlebar throttle.
im a little stumped as im pretty sure i've covered everything but
this nuicance is percevering.
i have also greased up the linkage pulley that holds the wire end on the top connection point at the handlebar.....
the cable is not bent and is free from any kinks.
the butterfly on the carb is free and returns well when done manually with the hand.
ahhhhhhhhh.......who knows of this problem and can shine some light ????
met
Old Oct 15, 2012 | 05:18 AM
grbrown's Avatar
grbrown
Hi from the UK. I'm not sure I can be much help, however here goes. The mechanism has several components, which can be tested on their own, disconnected from the bike. The carby butterfly is free, so have you dismantled the rest of the throttle mechanism and tested each part? I wouldn't be surprised if the cable itself is stiff, through corrosion or just old age.
So if you haven't done so yet, pull it all apart and check each part for proper operation.
You might get a better response in HDF if you post in the shovel section. This 'Other' one is out in the wilderness!
Old Oct 15, 2012 | 05:59 AM
met's Avatar
met
yeah thanks i will try the shovel section....
Webdude75
Dec 5, 2013 05:05 PM
met
Shovelhead
14
Oct 26, 2012 01:14 PM
met
Shovelhead
Oct 8, 2012 04:54 PM
dino1
Shovelhead
Feb 19, 2007 11:44 PM
LAZYBOY
Aug 29, 2006 10:07 PM
