Really basic stupid question!
Old Feb 11, 2007 | 06:40 PM
Protrucker's Avatar
Protrucker
Default Really basic stupid question!
OK..........call me stupid!
I bought my wife an '05 Low Rider & want to hook up a battery tender, but don't see how to remove the battery cover. On my Street Bob there is a screw under the battery that holds the cover on, but the Low Rider is different. I removed the seat & still don't see how. What's the trick?
I plan to buy a service manual, but haven't gotten it yet.
Old Feb 15, 2007 | 12:55 AM
Oldtimer of NM's Avatar
Oldtimer of NM
Default RE: Really basic stupid question!
Have the same problem with my OL's Lowrider. I think it's a childproof battery cover, which means only a child can open it. As a last resort, you can connect up to the battery side of the starter solenoid for your battery tender.
Old Feb 15, 2007 | 10:35 AM
rh8234's Avatar
rh8234
I thought someone with an '05 would have replied by now. I have an 03 and the battery cover is removed by removing the 1/2 inch bolt that goes into the frame horizontally and loostening the 1/2 inch bolt that goes it vertically (straight up). this allws you to push the battery box downward enough to remove the cover. If the 05's are similar, this might be what you need to do.
Old Feb 15, 2007 | 11:05 AM
ultraultra's Avatar
ultraultra
You need a manual... best $58 you'll spend! That's about 45 minutes labor charge. You do the math!
Old Feb 15, 2007 | 11:47 AM
EVOrider's Avatar
EVOrider
The first Dyna series were the same way. The '98 and '99 are the same way...I would believe the newest to be the same though.
Old Feb 15, 2007 | 01:50 PM
hdbiker's Avatar
hdbiker
ignore
Old Feb 15, 2007 | 02:08 PM
hdbiker's Avatar
hdbiker
See attached
[IMG]local://upfiles/3680/42E4DED8BF2A434C8D70903854E79067.jpg[/IMG]
coop creek
Oct 9, 2017 07:03 AM
RKLeo
Mar 23, 2009 01:07 PM
wideglidebob
Oct 19, 2008 02:52 PM
wideone
Mar 21, 2008 07:13 AM
Protrucker
Feb 11, 2007 07:36 PM
