Shovelhead Speedometer
Old Mar 4, 2013 | 11:01 AM
Knuck213's Avatar
Knuck213
5th Gear
Default Shovelhead Speedometer
Hopefully somebody can help me here. Quick background on my bike, its a 1977 FLH, Shovelhead, with a Baker 6-Into-4 transmission. The transmission has a port for an electronic speedo, but it seems that would only work if it was in a newer motor with an ECM, etc. Thus, I've resorted to the fact that I need a mechanical speedo. It hasn't worked since I bought the bike and the trip reset pin is snapped off (no cable, I assume this was due to the transmission swap.) I know you can get a front wheel drive speedo set-up; was wondering if anyone has used these or had any luck with them. I know I need the 2240:60 ratio for my 16" front tire. Also, under the speedo, there is a hole in the frame where it looks like the original cable would've been fed through, but if I were to run a front wheel speedo, it seems like the cable might get in a bind. I haven't really torn everything apart yet (been working on other parts of the bike) but wanted some input. Thanks in advance for any help you all can provide.
Old Mar 11, 2013 | 10:32 AM
grbrown's Avatar
grbrown
Harley used a transmission driven speedo on FLHs up to the early 80s, so that port may be for a cable driven speedo? Mark of Baker occasionally corresponds on HDF, although he may not see this post. I suggest you email or phone him for advice. Baker is a sponsor so bound to be keen to help. If they can advise on a suitable cable speedo drive, the appropriate speedo will naturally follow!
Old Mar 19, 2013 | 10:53 PM
Knuck213's Avatar
Knuck213
5th Gear
grbrown - Thanks for the insight and response. I agree with your thought that the 'port' is most likely where the old trans. speedo cable would've gone. The new Baker transmission has a provision for electronic speedometers only, so I will have to run a front wheel speedo. I decided to go with a 21" front wheel/tire combo, but if I remember correctly, the 21" has the same 2240:60 ratio as the 16"...? Speedo isn't really a necessity at this point...I can guess haha
Old Mar 28, 2013 | 09:01 PM
TwiZted Biker's Avatar
TwiZted Biker
Your's would still be the 2-1 ratio harley didn't go to that oddball 2240:60 nonsense till after 1980 sometime . Check the Vtwin catalog listing on line if I remember they have a chart that what years for which ratio drives . Gonna be off at least 10 to 15 mph anyway you go , always are .
Old Mar 29, 2013 | 01:22 PM
Knuck213's Avatar
Knuck213
5th Gear
Thanks for the info Twizted. What's the deal with the MPH gap, being 10-15 MPH off?...just cheap stuff, bad design or what? If that's the case and it's pretty much a certainty, then I'm not going to screw with it...only reason I wanted to fix it is just because I want to know how fast I'm going and use it as a reference and maybe keep myself from having any run-ins with law enforcement.
Old Mar 29, 2013 | 01:48 PM
TwiZted Biker
Honestly I think it's a combination of things , gearing changes , belt drives changing the primary ratio's , tires dia. changes and some being aftermarket stuff since the late 70's , the OEM gear was close but never accurate . Don't think I've ever owned one that read within 5mph of right , brit or harley . I've always done a poor mans check with somebody on 4 wheels giving the readings while I checked my mine and I figure the error in when I do pay any attention to the speedo , rode by feel for so many years without speedo's it's reflex .
Old Mar 29, 2013 | 06:16 PM
Knuck213's Avatar
Knuck213
5th Gear
Haha I figured as much. My bike is all stock but the transmission; typical 1977 ~74" Shovel, closed chain primary, Baker 6-Into-4 transmission. I've had the bike for a year now and haven't really paid attention and have used the poor man's method as well. I might just keep doing that and direct those funds elsewhere on the bike. If I get hassled about speed I guess I have an excuse haha... Thanks for the input bud, that's a beaut of a bike you've got yourself.
fredskie
Shovelhead
Jan 19, 2020 10:42 AM
jrsmith313
General Topics/Tech Tips
May 7, 2017 09:07 AM
thumper89
Jan 7, 2015 05:06 PM
92oldskoolxlh
May 5, 2013 09:19 PM
Dumaine
Apr 4, 2009 12:27 PM
