timing problem
Old May 14, 2013 | 11:35 PM
hrly762002's Avatar
hrly762002
Default timing problem
I have a 98 fat boy that I put together and my problem is that I have to advance the timing past the point that I have to loosen the screws and go farther yet just to get it to run. I checked the timing on the cam just to make sure I wasn't a tooth off, and everything is fine there. the bike is all stock stock heads, pushrods, pistons, cam, ect. I changed the module and ignition sensor twice and still the same. no difference the only thing is that I used 1998 flh fulie flywheels the ones with the fins on the for a crank trigger I was told the were the same except for the fins for the crank trigger if anybody has any ideas or need more info let me know
Thanks
Old May 15, 2013 | 06:29 AM
JohnFlorida's Avatar
JohnFlorida
Timing cup slipped or voes not working correctly maybe.
Old May 15, 2013 | 12:50 PM
hrly762002's Avatar
hrly762002
checked the timing it is seated in the notch not using voes is it possiable for the pinion gear key to be sheared enough to offset the timing
Thanks
Old May 16, 2013 | 10:38 AM
JohnFlorida
yes it is
Old May 16, 2013 | 12:16 PM
hrly762002's Avatar
hrly762002
Thanks for your help. I will pull it apart this weekend and see what happens. I didn't think those keys were that delicate. but everything else is lined up the way it is supposed to be. I have stock pushrods in it, so I am not to thrilled about having to remove the rocker boxes to get the pushrods out. might just cut them and put adjustables in it. il let you know what happens . thanks again
Old May 18, 2013 | 10:43 PM
hrly762002's Avatar
hrly762002
took it apart only to find that the pinion key was fine no damage aor anything Im lost. don't what else to do..
98hotrodfatboy
Aug 22, 2018 01:48 PM
traildog
EVO
33
May 18, 2014 10:22 PM
gsxrboy96
EVO
Oct 11, 2011 07:10 AM
HD47knuckle
Shovelhead
Aug 13, 2010 04:01 PM
Greybeardrider
EVO
Aug 10, 2007 07:57 PM
