How old is your drive belt??
Old May 27, 2014 | 02:23 PM
Mike96Coupe's Avatar
Mike96Coupe
Stage II
Default How old is your drive belt??
I picked up an 03' Heritage Classic it has 10,000 miles on it. Should I be concerned with an 11 year old belt??
Old May 30, 2014 | 01:43 AM
02FXSTI's Avatar
02FXSTI
4th Gear
Still running the original 2002 belt; 30k on it w/ 110HP.
Old May 30, 2014 | 06:10 AM
LokiBobber's Avatar
LokiBobber
Is there an interval that's recommended before changing out the belt or does a guy just check it once in a while for signs of wear?
Old May 30, 2014 | 07:52 AM
HDmikie's Avatar
HDmikie
A guy I know has a 99 Wide Glide with 110,000 miles and still using original belt. My 02 Fatboy has 20,000 miles.....I just keep checking for cracks at every oil change.
Old May 30, 2014 | 08:07 AM
ZUTEDUFF's Avatar
ZUTEDUFF
62000 on mine...just check when servicing.....
Old May 30, 2014 | 02:37 PM
revnrob's Avatar
revnrob
31,000 here.
Old May 30, 2014 | 02:40 PM
woodsietx's Avatar
woodsietx
55,000 mi as far as I know. Gets checked over every service and so far hasn't needed changed.
Old Jun 1, 2014 | 12:05 AM
deadhawg's Avatar
deadhawg
As long as a rock or something doesn't get caught in the belt, it should go 100,000 miles. I got 110,000 out of my last belt, 10 years old, still looked good, only changed it because I was prepping for a cross-country loop and didn't want to take a chance on it.
Old Jun 2, 2014 | 02:52 PM
Mike96Coupe
Stage II
Cool, that is what I was hoping to hear. Thanks.
Old Jun 7, 2014 | 10:32 AM
Strahley's Avatar
Strahley
I'm at 43k miles on my bike (2002 FXSTI), and last summer I started having a growling, winding-down noise coming from the rear. It only happened when it was hot outside (95+). The research and advice I got was that either the belt was worn or something wasn't aligned correctly. I decided to just tear it down and replace it since I have a lot of other stuff I wanted to do as well (that required digging deep into the bike)
I got the belt off a few weeks ago and it did look pretty worn. I have a new belt that should be in today, so I can compare the two
