Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Speedometer question
Old Oct 12, 2008 | 10:30 PM
zoood's Avatar
zoood
Former Sponsor
So I guess that means, when Im on the interstate. If I let cars pass me and trucks almost run me over. I should be doing about the correct speed limit.
Old Oct 13, 2008 | 12:02 PM
rwagon57's Avatar
rwagon57
Measure the circumference of the 16-inch tire mounted on the rim and properly inflated, then measure the 21-inch tire in the same manner. Divide the measurement for the 16-inch tire by the measurement for the 21-inch tire. That will be the speedometer correction. If the answer is 0.9 that means 65 mph indicated is 58.5 mph actual (speedometer reads fast), if the answer is 1.1, that means 65 mph indicated is 71.5 mph actual (speedometer reads slow). The faster the speed the greater the error.
sasquatch_38
Wheels/Tires
Jun 28, 2013 06:30 AM
hellbob37
May 19, 2012 10:44 AM
hpjunkie
Jun 3, 2011 08:18 PM
FXSTaCy
Jun 6, 2009 07:55 PM
zoopman
Sep 29, 2007 11:41 PM
