Questions about wheels and speedometer...
Old Sep 28, 2007 | 08:49 PM
zoopman's Avatar
zoopman
Default Questions about wheels and speedometer...
I have an 07 fxd and found out a few things. If ya stay with the stock rearwheel (17x4.5)and want a 180 reartire---ya have only one choice and dunlop makes the tire for HD only. It seems that no other 180 tire will fit this wheel size. I am thinking of going to an after market 18x5.5 wheel so I can use any 180 brand tire in the future. Been thinking about some sharp lookin chrome wheels someday as they are costly! My biggest question is--by changing wheel and tire size will seedometer still be correct? My understanding is that the speedo cable goes directly into transmission connected to vss (vehicle speed sensor) and that wheel size will not be an issue. Anybody ever look into this?
Old Sep 28, 2007 | 10:02 PM
murphdog's Avatar
murphdog
Default RE: Questions about wheels and speedometer...
If the diameter of the back tire changes, the speedometer will be off. If the diameter increases from stock, you will be going faster thanthe speedometerindicates. If the diameter decreases from stock, you will be going slower than thespeedometerindicates.
Old Sep 29, 2007 | 07:15 AM
soup48's Avatar
soup48
There is no speedometer cable. There is only the VSS that gives the info to the speedo.
Old Sep 29, 2007 | 10:29 AM
zoopman's Avatar
zoopman
Yes soup48 you are right--I should not have said cable!-- murphdog I understand what your saying and agree but does the vss get it's info from wheel/tire diameter? Was talking to someone (can't remember who dang-it) and they were saying wheels size would not matter as speedo reads from transmission. Not a big deal and sure don't want to beat a dead horse with this--but I have learned much here on this site from all you guys!! Thanks
Old Sep 29, 2007 | 10:43 AM
StreetBobJason's Avatar
StreetBobJason
If the diameter of tire changes then the RPM inside the tranny changes. Therefore it would vary speedo.
'06FXDBI, My first HD!
Old Sep 29, 2007 | 08:38 PM
jeffbcn's Avatar
jeffbcn
This has got to be a straight math question. Larger diameter at same rpm would result in greater distance traveled, right?
Old Sep 29, 2007 | 08:41 PM
murphdog's Avatar
murphdog
zoop, the speed sensor is looking at teeth on a gear in the transmission. If you change something after the transmission, the speedometer will be off. A larger diameter tire travels a greater distance per revolution. So, for a given revolutions per minute of the transmission gear and rear tire, you're traveling a greater distance per minute (going faster) than the speedometer thinks you are.
I put tires on my truck that are 5% taller than the stock tires. Guess what...the speedometer and odometerare 5%off and yes, the sensor is in the transmission.
Old Sep 29, 2007 | 09:49 PM
zoopman's Avatar
zoopman
murph--with this info I will measure wheel and tire diameter to see how much of a difference and then drive along with someone to check speedo at a few different speeds. At least I would have an idea and perhaps avoid a ticket.Just trying to figure all this out if I do decide to buy the chrome wheels. Thanks again guys!!
Old Sep 29, 2007 | 11:41 PM
mdog2222's Avatar
mdog2222
Nice thread man. Good topic
sasquatch_38
Wheels/Tires
Jun 28, 2013 06:30 AM
yank
Sep 20, 2012 05:06 AM
Joe741
Dec 30, 2011 09:46 PM
hpjunkie
Jun 3, 2011 08:18 PM
zoood
11
Oct 13, 2008 12:02 PM
