handle bar recommendations
RJ
These bars sit higher and sweep back at you so your not having to reach as far forward when doing full lock turns. They are reasonably priced at around $70
Heres the website >> http://www.khromewerks.com/
I had the same issue. I'm 5'11" with a 29" reach. Armpit to my fingertips.
Even with a 4.5* rake and the stock bars I had to lean forward and it put me on the seat incorrectly. Hurt like a mother on my ****, neck and back. I too got the Khrome Werks +2 bars installed. HD makes a set too.. 55914-98 Pull Back Bars
One thing to remember when you change +2, Pull Back or Tall Boy bar. The clutch cable, both throttle cables will need to be changed. Also the switch wiring must be lengthened on both sides.
Well worth it and a great mod.
Touring Pull Back Handlebar*
These high quality, polished stainless steel handlebars are
designed to bring the controls 2" closer to the rider for increased
comfort. Especially helpful for shorter riders or those with short
arms. Separate brake line, clutch, and throttle/idle cables are
required for proper installation.
55914-98 Fits 97-07 Electra GlideŽ models
(except FLHX and models equipped
with Fairing Mount Mirrors). Requires
separate purchase of Clutch Cable
P/N 38649-98 (97-06 models),
or 38649-07 (07 models) and Brake
Line Kit P/N 45212-97B. Not compatible
with Hydraulic Clutch Kits. Requires
separate purchase of model-specifi c
throttle/idle cables. $49.95
Throttle and Idle Cables for Tallboy and Touring
Pull Back Handlebar (not shown)
Required to install Touring Pull Back Handlebar P/N 55914-98
and Tallboy Handlebar P/N 56964-07.
Throttle Cables
38650-98 Fits 97-07 FLHTI, FLHTCI,
and FLHTCUI models. $21.50
56357-96 Fits 97-06 FLHT, FLHTC,
and 97 FLHTCU models. $22.00
Idle Cables
38652-98 Fits 97-01 FLHTCI. (FLHTCI
models equipped with Accessory
Cruise Control Kit require the use
of Idle Cable P/N 38651-98.) $21.50
38651-98 Fits 97-01 FLHTCUI models. $35.00
56424-98 Fits 97-01 FLHT and FLHTC models. $21.50
56071-98 Fits 97 FLHTCU models. $35.00
56730-03 Fits 02-07 FLHT/I, FLHTC/I
and FLHTCUI models. $22.95
D. Chrome Throttle and Idle Cable Adjuster Covers
Replace the black rubber throttle and idle cable boots with brilliant
chrome. Machined from billet aluminum, this two-piece ballmilled
dust cover offers a striking contrast to Original Equipment
black cables, and a natural fi nishing touch when installing
braided cables. Easy-to-install with included hardware.
64115-04 Fits 96-07 Touring models (except
FLHRS with Original Equipment handlebar),
and 96-later FXSTB and FLSTC, and 05-later
FLSTN. Will fi t 05-later SoftailŽ models
equipped with separate purchase of a
Front Turn Signal Relocation Kit. $59.95
*NOTE: Installation of some handlebars may require a change
in clutch and/or throttle cable and brake hose for some models.
Handlebar height is regulated in many states. Check state or
local laws before installation.
RJ
Thank you for all the info.
Throttle Cables
Idle Cables
