Power Vision Question
Old Jan 27, 2015 | 02:12 PM
Big Money's Avatar
Big Money
Default Power Vision Question
I recently changed sprockets on my 07 FLHX, I changed from stock 32/66 to 30/68. I need to recalibrate my speedometer. I know I have to raise the value in the speedometer calibration in Winn/PV. Would anyone know how much I raise the value and how I do it in Winn/PV.
Old Jan 27, 2015 | 06:37 PM
harleytuner's Avatar
harleytuner
How much depends on what sprocket you went with and how far off it was before.
Old Jan 28, 2015 | 01:38 AM
ke5rbd's Avatar
ke5rbd
2265 if the current setting is 2078. If not just add 187 to your current number. If your speedo is already off 2 mph fast as most are then add 58. You can check it with gps and for each mph fast add 29 points. These may not be exact, but speedos vary in accuracy from low speed to high speed also. I choose to get it right around 60 in 6th.
Old Jan 28, 2015 | 05:52 AM
Big Money's Avatar
Big Money
Thanks for the info, I think I did it right. I went into Winn/PV brought up my tune my current setting was 2058 so I added 187 to that and made it 2245. I saved changes then uploaded tune onto Power Vision. Now I need to hook up to bike and flash with updated tune. Is that correct or did I make a mistake?
Old Jan 28, 2015 | 12:26 PM
ke5rbd's Avatar
ke5rbd
that is the correct procedure. When it asked to reset learned just tell it no, since you haven't changed any of the fuel mixtures or timing. Be sure it is calibrated right before pushing the speed limit. My stock 10 limited was off 2.5 mph fast. After resetting and adjusting for the 2.5 it was dead on with 2 different GPS's.
Old Jan 28, 2015 | 01:01 PM
Big Money's Avatar
Big Money
Thanks I appreciate the info, I'm slowly learning how to use the Power Vision.
Old Jan 30, 2015 | 12:33 PM
SBates08's Avatar
SBates08
2245 is what I set mine at when I changed to the 30T on my '10 Limited. 2245-30T/68=dead on perfect.
2010 Limited with some stuff!!
Old May 30, 2015 | 06:45 PM
InTheWinda1's Avatar
InTheWinda1
BUT a thought ,, are you talking about bike speedo or the PV speedo ?,,My PV speedo is about 2+ mph slower then my bike speedo ,2007 FLHTCU 103"
JIM
Old May 31, 2015 | 12:45 AM
ke5rbd's Avatar
ke5rbd
[QUOTE=InTheWinda1;14068590]BUT a thought ,, are you talking about bike speedo or the PV speedo ?,,My PV speedo is about 2+ mph slower then my bike speedo ,2007 FLHTCU 103"
JIM[/
the Bike speedometer unless you have changed it in the PV is likely off. check it with GPS as the PV is still a calculated number.
94 ultra
2014-2024 Touring Models
Jan 8, 2019 07:13 PM
Reindeer
Jun 30, 2017 10:22 AM
patrickd
Sep 11, 2014 04:37 AM
mdanehart
Feb 26, 2014 01:42 PM
plumberdoug
Oct 17, 2012 01:39 AM
