Timing adjustments and Timing patterns
Old Mar 13, 2016 | 07:36 PM
IKnowNot's Avatar
IKnowNot
Couldn't whittlebeast put together a how to sticky tutorial for all of us PV users. That would enable us to use his software to tune the timing tables. He could do step 1: how to tune your VE tables and step 2: how to tune your timing tables.
Your PV should take care of the VE tables.
As far as timing, I believe that was the purpose of this thread, for us to help him develop a method to tune and/or check the tuning of the timing tables without the need of a dyno.
Old Mar 13, 2016 | 08:51 PM
whittlebeast's Avatar
whittlebeast
Fuel is quite a bit easier to get your head around.
I did a thread on "scatter plots for beginners" on a different forum. I could do one here if the mods don't mind. The basics work on anything you are tuning and with any tuning software.
Old Mar 13, 2016 | 09:02 PM
oleboy's Avatar
oleboy
Ok, I Just thought he could roll all of it up in one thread.
Old Mar 13, 2016 | 09:06 PM
oleboy's Avatar
oleboy
That would be great on this forum. Please start one. I'm so confused looking at the scatter plots. Any help would be appreciated.
Old Mar 13, 2016 | 09:09 PM
oleboy's Avatar
oleboy
That would be awesome. If you could walk us through what we need to adjust based on the scatter plots for AFR and timing that would be helpful.
Thanks!
whittlebeast
See http://www.nbs-stl.com/tuning/BasicTuning101.pdf
At the end, I cover scatter plots and what they are.
Andy
Old Mar 13, 2016 | 09:16 PM
whittlebeast
In all of this scatter plot stuff, you have to accept that MAXxRPM is essentially air flow and really HP if you if you divide by the right number. This assumes that your motor does not have some strange thing going on. Most motors in the world do not have this sort of thing happening. An example could be things like a stopped up catalytic converter.
Keep in mind that if the timing is really screwed up, this assumption is not even close.
Andy
Old Mar 13, 2016 | 10:32 PM
IKnowNot's Avatar
IKnowNot
Here is what I am thinking my be worth trying. See the red line on the right. The goal is smooth running motor with very little but occasional slight knock retard.
http://www.nbs-stl.com/HarleyTuning/HarleyTiming.jpg
Andy
I was reviewing that and was wondering where it came from (a known, well tuned Harley?)
As I said, mine looks nothing like that!
But what I found is, if, in the right pane, you change the field to Duty Cycle it reveals where the lower dog-leg comes from.
Don't know if that helps, but ...
Old Mar 14, 2016 | 06:02 AM
whittlebeast
IKnownot
You are so seldom riding above 58 KPA that you are simply not filling in the dots. The guy that generated that data runs his motor way harder.
Old Mar 14, 2016 | 06:56 AM
whittlebeast
Here is what a lot of data looks like. This guy runs the crud out of this bike.
http://www.nbs-stl.com/HarleyTuning/...ing%20Data.png
Andy
