Timing adjustments and Timing patterns
Old Mar 14, 2016 | 10:23 AM
IKnowNot's Avatar
IKnowNot
I'm old and take my time (with everything.)
Actually, chose that log to work with because it has all my latest changes. Unfortunately it is missing the most aggressive parts of the ride ( WOT, powering through some twisties ) because I shut the bike down waiting for a train and forgot to start the log again.
Sometime this week I will try (weather permitting) to get a longer log and try to hit more areas, but here is one from an earlier tuning run hitting those areas ( has some minor differences is rear spark tables, some others. )
Old Mar 14, 2016 | 11:04 AM
whittlebeast's Avatar
whittlebeast
If you make the color the same thing on both sides, it is easier to figure out what you are looking at. In your example above, I would make the z axis = Advance F.
Old Mar 14, 2016 | 01:27 PM
IKnowNot's Avatar
IKnowNot
Noticed that after I posted it. In the first one of those I posted I was searching for where certain points came from.
Picture updated, field changed.
Old Mar 14, 2016 | 01:35 PM
whittlebeast
If you tag any point on one side the other side will circle where it happened on the the other page. The log screen will also jump right where your were at. They are all synced. It really helps getting your head around what is going one at any point in the log.
Andy
Old Mar 14, 2016 | 06:48 PM
IKnowNot's Avatar
IKnowNot
Actually I have been playing with that. Picking a point, checking the time stamp, then looking at the spreadsheet to see exactly what it is doing ( trying to get used to the patterns and what is where in them.)
I even put the two logs together to see the entire range.
Only problem I am having is that damn mouse-over keeps getting in the way.
Old Mar 14, 2016 | 10:53 PM
oleboy's Avatar
oleboy
Originally Posted by whittlebeast
See http://www.nbs-stl.com/tuning/BasicTuning101.pdf
At the end, I cover scatter plots and what they are.
Andy
Thanks for the link! I'm still confused though. I just can't figure out how I can adjust anything using those scatter plots with any precision.
I currently pull data logs and import them into Excel and sort them. Doing so, I can make VE table numeric changes based on those logs. How do I do that using those scatter plots?
I want to use the scatter plots but I really don't know how to make changes based on what I see.
When I use the data import Excel method, for example I can see a CLI % change and see that ECM is changing the VE table from 96 to 108 at 3200 RPM/ MAP load 65. I can go into the MAP and edit the VE table based on that. Maybe I shouldn't be doing that.
How do I use the scatter plot method to do the same? How do I know how much to adjust the VE tables based on the scatter plot?
Thanks.
Old Mar 15, 2016 | 06:26 AM
whittlebeast
If you are talking about adjusting fuel with scatter plots, it may be better to start a different thread. I have that sorted.
Andy
Old Mar 15, 2016 | 11:32 PM
oleboy's Avatar
oleboy
Andy
I'm asking about both the VE tables and the spark tables. I want to know how to import my logs into the software and how to make changes to my VE tables and spark tables based on what I see on the plots. As I indicated before, I have been using Excel to import the logs and make those changes. Where is the thread that you reference that explains how to do this? I searched the internet using your user name and saw numerous posts on a number of EFI forums (alot non Harley). None of them really explained in detail a step by step process on how I would use this software to make changes to my VE or spark tables. For someone that promotes this software, you seem to be pretty elusive about explaining in detail how to use it to an end user.
Why don't you start a post that explains the step by step process of how a novice user like me should use the software. I'm frustrated. I imported my logs into the viewer and I can't make heads or tails of what those plots are showing me. Its way more confusing than the spreadsheets.
Thanks.
Old Mar 16, 2016 | 04:15 AM
mirrmu's Avatar
mirrmu
haha, oleboy this has been asked many times
i would like to see piece of info from the logs/or plots and then how/where to change your VE table or your timing table
X plot, or X data from log says I have to increase VE by 3% at 80-100kpa and from 4500rpm to 6000rpm
Old Mar 16, 2016 | 06:05 AM
whittlebeast
The problem with coming up with a cookbook method is
With or narrow bands or wide bands
Closed loop on or off
Long term trims on or off
Power Vision, Target Tune, Thunder Max or TTS
Hand tuning or auto tuning
Sportster, V Rod or BT
Speed Density (MAP) or Alpha-N (TPS)
That is a bunch of combinations.
