Just a P0134 code
Old Aug 21, 2016 | 06:57 PM
duner50's Avatar
duner50
Stage III
Default Just a P0134 code
Need a little help! I have an 08 ultra classic installed Big sucker II and a Fi2000r powerpro I get P0134 code. So I changed the o2 sensor same code bike hesitating and popping.Not sure what to do next I checked connection.
Old Aug 21, 2016 | 10:17 PM
Doc 1's Avatar
Doc 1
The code doesn't say the 02 sensor is bad, it's telling you the AFR is too rich or too lean by reading the voltages. Example; if the 02 report voltage, in your year bike, is above 800mv its running rich, if it is below 600mv it's too lean. When the ECM see's the voltages out of normal pramiters it will through a code. Changing the 02 sensor won't change the AFR.....your settings on the Cobra are wrong.
Doc
Old Aug 24, 2016 | 10:15 AM
duner50's Avatar
duner50
Stage III
The problems is there are no setting on the cobra it is a continuously variable tuner.
Old Aug 24, 2016 | 10:18 AM
Doc 1's Avatar
Doc 1
Then get rid of it and get a GOOD tuner.
Old Aug 26, 2016 | 02:52 PM
duner50's Avatar
duner50
Stage III
I removed the BIG SuckerII and the Tuner no codes! but I still get a misfire and popping at midrange. I've got new plugs.MAP sensor?
Newfie
Milwaukee Eight (M8)
Apr 28, 2019 08:29 AM
kch112654
Oct 13, 2018 07:25 AM
Highgrade
Oct 1, 2015 06:57 PM
RustyCage
Aug 10, 2015 12:21 PM
Deuce55
Sep 23, 2014 07:11 PM
