Trouble codes
Old Sep 21, 2017 | 09:50 AM
cowboybob56's Avatar
cowboybob56
Default Trouble codes
P0122 TPS open low, kicks out a Pn32915-07. This doesn't cross over to any part number on Ronnie's parts finder. What is it?
Old Sep 21, 2017 | 01:47 PM
FLTRI17's Avatar
FLTRI17
First, clear the code and see if it comes back. If it does check the connection and if good buy a new sensor from the dealer or aftermarket. No idea what "kicks out a p/n" means but the parts manual will provide the correct number.
Bob
Old Sep 21, 2017 | 09:37 PM
Ed Ramberger's Avatar
Ed Ramberger
He's reading the module info that shows up as well.
Don't just buy a sensor. The code means there is a problem in the circuit. That includes wires and the sensor. Take some time, check the wiring for breaks at the sensor connector - insulation will feel stretchy if you pull on it if the internal wire is broken.
Grouser62
Apr 1, 2019 12:17 AM
KennyPowerz
General Topics/Tech Tips
Jun 6, 2018 10:30 AM
just plain john
Sep 9, 2016 07:11 PM
coachchris
May 9, 2011 11:42 PM
F1J1
Oct 22, 2008 05:20 PM
