Start engine in gear?
Old Dec 5, 2017 | 04:58 AM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by jbarr1
There is always some clutch drag. Do yourself and the starter system a favor and only start in neutral.
The only time I'd start in gear is after a stall in traffic. My 2002 will engage the starter in gear with the clutch lever out, no interlock.
Old Dec 5, 2017 | 01:18 PM
bustert's Avatar
bustert
if you can walk and chew gum at the same time, then an in gear start is a no brainer!!
if your clutch fully dis-engages then there is not any notice-able drag to the starter.
Old Dec 5, 2017 | 01:33 PM
Ron750's Avatar
Ron750
I always start in neutral, except for a stall. I'm a big believer in Murphy's Law. When I first had my bike, I started it in gear and lurched the bike forward. Bad feeling.
I feel a drag on the starter with the clutch fully depressed, and it is adjusted properly. YMMV.
Old Aug 18, 2019 | 05:26 PM
back again's Avatar
back again
Common for older bikes
Old Aug 19, 2019 | 01:21 PM
FLTRI17's Avatar
FLTRI17
IMO, it is of utmost importance that you can restart the bike in gear when stalled...WITHOUT having to rock the bike back and forth to find neutral so the bike can be restarted. This can be very dangerous stuck out in the middle of an intersection at rush hour with a bike you can’t restart by simply pulling in the clutch lever and hitting the start button.
Be sure you neutral safety switch is working condition by trying to start the bike in gear with the clutch lever pulled in.
Bob
PS- Early bikes did not have neutral safety switches. They would start in gear without pulling in the clutch lever.
mitman76
May 12, 2019 04:48 AM
ottawaair
Mar 10, 2018 12:36 PM
cajun1957a
Apr 18, 2016 06:56 PM
TurkeyRun
Nov 12, 2012 09:44 AM
SICKBAGGER
Apr 26, 2012 09:31 AM
