Tuning a Twin Cam
Old Jun 11, 2018 | 07:14 AM
eglideic's Avatar
eglideic
Default Tuning a Twin Cam
I have no interest in going fast, but I helped a friend install a 117" kit with a larger throttle body and injectors, in his 2014 110" Softail. I know nothing about tuning or mapping or down loading or any of that. He put a Vance and Hines Fuelpak in the bike and tuned the motor with his phone. He says it runs fine till about 3000 RPM, when it starts acting up and there's a flat spot and it's cutting out. He thinks we did something wrong. I'd say, if we did something wrong, like got the cams off a tooth or something like that it would run bad all the time, and not at just a certain RPM. I think he got the wrong tuning info from Vance and Hines. What do you guys think?
Old Jun 11, 2018 | 07:25 AM
jbarr1's Avatar
jbarr1
Instead of using the phone to tune the bike, use the phone to order a TTS and to call a real dyno tuner and he’ll fix the issues! Sounds like a bad base map from V&H. I doubt they’ll be much help with a 117. The fuel pak was really designed for closer to stock engines. I doubt it’s anything you did because, as you said, it runs fine down low.
Old Jun 11, 2018 | 08:39 AM
Max Headflow's Avatar
Max Headflow
Get the bike tuned with a real tuner.. You can burn up a 117 real easy.
Old Jun 11, 2018 | 09:04 AM
Ed Ramberger's Avatar
Ed Ramberger
Take it to a professional or you will be rebuilding it again.
GalvTexGuy
Fuel Moto / Jackpot Mufflers
Apr 14, 2019 08:23 AM
Bongiorni706
Feb 9, 2019 11:20 AM
marcelm
Nov 12, 2018 09:27 AM
Papa Joe
May 16, 2013 06:51 PM
Gregory Agee
Oct 19, 2012 09:41 PM
