Battery harness
Old Oct 26, 2005 | 12:54 AM
hdrider2134's Avatar
hdrider2134
Stage III
Default Battery harness
Does anybody know if the Battery Tender Jr will work with the pre-installed from Factory harnesses on the new 2006 models. There seems to be three holes on the new harnesses and only two plugs on the battery tender jr.
Old Oct 26, 2005 | 09:59 AM
HDF Tech's Avatar
HDF Tech
Default RE: Battery harness
You should be able to wire the harness that comes with the charger with the 2 wire harness direct to the battery itself for the hook up of the charger.
Old Oct 26, 2005 | 03:37 PM
hdrider2134
Stage III
Thanks, the harness comes already wired from the factory on the 2006 Fatboy but is has three inputs rather then the old style of two. My batter tender jr that I have had for quite some time only has two outputs, just wondered if it would still work wit the new harness already installed. Thanks and I apologize for the confusion. My tech talk is not quite adequate in most case, lol
Old Sep 1, 2006 | 12:50 PM
4DZTOY's Avatar
4DZTOY
Does anyone know what the third contact does in the newer pigtail? I asked my dealer at delivery and he said something about a newer style charger....but he didn't have it....I checked out the Del-Tran web site....don't see any three contact set ups there....I've been plugging my Battery Tender Jr in and it seems to work fine...but I'm curious what the other terminal is for????
sgnden
2014-2024 Touring Models
27
Oct 16, 2018 06:40 AM
benningtonr
11
Mar 4, 2017 07:10 PM
d-streetglidr
Dec 1, 2013 08:18 AM
deadman77
Aug 11, 2013 07:48 PM
sportster2
Nov 10, 2008 06:43 PM
