Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a question regarding the EITMS. I noticed that the EITMS on my 2015 Tri Glide Ultra is in disable mode and it won't go into enable mode. The cruise control light doesn't flash green or orange per the owners manual. With that said, I have made the following stage 2 performance upgrades:
Thunder max tuner
Upper engine work (heads, pistons, cams, pushrods, etc)
Exhaust
Air box.
Are any of these mods the reason that the EITMS is no longer working or needed? Just curious. Not that I would have it enabled anyway.
Thunder max tuner
Exhaust
Air box.
Thanks for your feedback.
Isn't Thundermax a replacement ECM not a piggy back or flash tuner? If so the EITMS software has been removed with the factory ECM.
