Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Been known to happen on occasion , flash it back to the stock map , flash new map . Make sure your firmware is up to date by checking in the customer support section of the program , it usually does it automatically when you start the program , but .
Gearhead is correct , keeping your battery tender plugged in while doing changes will help keep the battery from draining .
9.9v is too low , with switch on it should read a min of 12v ... put the battery on a charger , not just a tender , run it at 2amps over night . Probably be a good idea to have the battery load tested as well , in case it has a bad cell . In the mean time , I would check all the connections , both ends of the POS and NEG cables and make sure they are clean and tight .
