Bad map sensor ?
Old Mar 25, 2020 | 09:13 AM
Janus3/33's Avatar
Janus3/33
4th Gear
Default Bad map sensor ?
Hey guys / gals . I’m working on my 99 dyna . It’s bored over to a 103 , stroked , cammed bike has ran after build for a few years pretty strong always keep up on general maintenance such as oil changes , plugs , wires , battery on a tender when parked . I started to notice it would run sort of “poor” or less power threw out the throttle ranges then one day it wouldn’t fire up at all and would cough out the carb with a few turns to the motor while trying to start. I went right ahead and replaced all the gaskets from the intake manifold , carb , air cleaner . Still same symptoms . I’m curious as to if a bad map would do this . The bike has no voes sensor . I don’t want to buy a bunch of parts if it could be something else that I’m missing but I think it’s a map but have no experience with one going bad yet . I also cleaned the carb and gave it the once over on all hoses / gaskets for leaks as well it checks out good
Old Mar 25, 2020 | 02:38 PM
marcodarq's Avatar
marcodarq
did you check for spark and compression? you need to confirm that stuff before moving to the map sensor.
m
Old Mar 25, 2020 | 02:44 PM
Janus3/33's Avatar
Janus3/33
4th Gear
Yes Have spark and have compression .
Old Mar 25, 2020 | 05:04 PM
Max Headflow's Avatar
Max Headflow
Whats the compression running? Which ignition are you using?
Old Mar 25, 2020 | 05:20 PM
marcodarq's Avatar
marcodarq
what carb? and what fuel valve, did you double check and confirm that the carb is getting fuel to the bowl? is the accelerator pump squirting?
m
Old Mar 25, 2020 | 07:50 PM
Janus3/33's Avatar
Janus3/33
4th Gear
Issue has been resolved with a map sensor off of my buddy’s bike thank god he was willing to do a quick swap out to help diagnose
Janus3/33
Sep 17, 2021 11:44 AM
hddave2
72
Aug 11, 2011 09:45 PM
Deuski
Exhaust System Topics
Nov 28, 2010 05:17 PM
onewayphil
Mar 18, 2008 11:35 AM
dennish
Dec 29, 2007 03:18 PM
