Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
yes thank you I just inspected all hose and wires It all looks new still..... I might just bite the bullet and get a HI-4N Crane This SE module is at least 15-20 years old.....and it better be the problem if I do this......
Very welcome.
I haven't checked prices lately, but you might also check out Dyna 2ki and or Ultima 53-644. The Crane (S&S now) had a bad rep and still does for some guys. The Dyna or Ultima have proven nearly bullet-proof for myself and countless others over the years. Only usable difference is the Ultima has faster max advance curves with WOT than the Dyna, which might be a concern with your strong build. But either one is easily programmable and a breeze to install.
Very welcome.
Well Stopped raining and was able to go deeper into this I changed the plugs took it out for a test went perfect hammered it to 4000k slowly to 4000k I said sweet just the plugs..... so on the way back it started it again 4k spitting spuddering losing power so I got pissed and kept the throttle full as it misfired It started to go passed 4k hit 5k started running great 6 k perfect rev limiter hit I backed down. hammered it again smooth as silk 100 mph perfect turned around hammered it, it did it again I mean WTF Im clueless and pissed....
Assuming you are running resistor spark plugs and not using wire core plug wires, I'm out of ideas.
I have zero experience with an S&S carb. I don't even read threads concerning them, but - I do remember guys saying if the boot on the accelerator rod is cracked/leaking (and it's hard to see unless you take them off), they'll cause all kinds of freaky problems. Just a thought.
Maybe post your symptoms in the carb, Evo or Shovel section. There's some sharp guys with lots of experience with those carbs on here... I'm not one of them though
I just change plugs from Champion copper to NGK Iridium Ix wires are Screaming eagle
Ive decided since I cant be 100 percent sure its ignition and the carb been on this bike for 20 years Im going the cheaper way and rebuild the carb....... thanks for your input guys
