2019 Road Glide no start after moderate crash
Old Jul 13, 2020 | 04:15 PM
fgilty's Avatar
fgilty
4th Gear
Unhappy 2019 Road Glide no start after moderate crash
Hi,
I bought this bike with key. When I turn the ignition I hear the fuel pump pressure up and the radio turns on. But the speed and rmp gauges dont come alive, just off as if no power. I press the start button and nothing. The starter doesnt turn or do anything. I checked all the fuses and they are all fine. What can I do next. Also the speed and rpm gauges are plugged in fine.
thanks,
Fred
Old Jul 13, 2020 | 04:21 PM
Iceman24's Avatar
Iceman24
Was the bike tipped over during the crash? Believe it or not there is a sensor (bank/angle) that trips so bike won't start until reset.
Old Jul 13, 2020 | 05:38 PM
fgilty's Avatar
fgilty
4th Gear
Yes it was layed on its side pretty hard. Where would I find this reset switch...?
Thanks,
Fred
Old Jul 13, 2020 | 05:41 PM
Kawickrice's Avatar
Kawickrice
Turn the ignition switch on and off 3 times.
Old Jul 13, 2020 | 07:34 PM
fgilty's Avatar
fgilty
4th Gear
I will try that tomorrow when I get back to the shop. Thank you for having interest in helping me out I appreciate it.
Fred
Old Jul 14, 2020 | 09:29 AM
NODYNA's Avatar
NODYNA
The bank angle sensor interrupts power to the fuel pump. It may also interrupt power to other control circuits. It resets 10 seconds after the bike is upright. Pull the main fuse for a master reset if that does not correct the problem you need to check every connection and battery capacity. It's possible some plates were damaged enough to still have 12 volts but not amps to power the starter.
danhahn
2014-2024 Touring Models
Sep 4, 2019 09:04 AM
Ryan Thomas Cox
Apr 30, 2019 10:32 AM
Tg waldog
Jun 19, 2018 12:40 PM
RoadKingCop
Oct 6, 2013 02:14 PM
rk10
May 9, 2012 04:33 AM
