Converting over
Old Dec 1, 2020 | 11:14 AM
Ed Ramberger's Avatar
Ed Ramberger
Originally Posted by tinymike66
Can I use the coil I got for carburated bike or do I also need a new one to go with the daytona?
I noticed Dynatec has a module as well???
H-D ignition coil should be compatible with the DTT ignition module. You can veriy with them, but I never remember having to change a coil for a DTT module. Back in the day, Screamin' Eagle ignition modules had some ignition module variations that required a coil change.
Old Dec 1, 2020 | 12:37 PM
tinymike66's Avatar
tinymike66
Will.i need a harness or will the ignition harness I have work?
Btw you have been a huge help.
I do appreciate all this info.
Cheers
Mike
Old Dec 1, 2020 | 12:50 PM
eighteight's Avatar
eighteight
Can I use the coil I got for carburated bike or do I also need a new one to go with the daytona??
Daytona website specifically states that there is no advantage to using any thing other than stock coil
( To your harness question I can only say that on my `99 the only change required to add DTT was disconnecting the cam position sensor wire)
YMMV
Old Dec 1, 2020 | 01:17 PM
tinymike66's Avatar
tinymike66
YMMV
Thank you
Old Dec 1, 2020 | 03:11 PM
Ed Ramberger
Cheers
Mike
As long as you have the proper ignition harness for that year, it will simply plug into the main harness and work. When I converted from Marelli to Delphi, I had to buy the proper plastic mount for the Delphi ECM. You will probably have to do the same for the ignition module.
Old Dec 17, 2020 | 05:17 AM
Madison Bill's Avatar
Madison Bill
When I converted my Deluxe EFI to Mikuni carb I installed the Thunderheart ignition and it works great. The Thunderheart comes with a new coil.
Johneb48
Carburetor Related
Jun 12, 2020 09:54 AM
harleyhogdude
Exhaust System Topics
Apr 28, 2011 05:41 AM
hdrider53
13
Mar 25, 2011 09:45 AM
sharkey
Dec 3, 2010 09:46 AM
jdreed520
Apr 1, 2009 12:28 PM
