Converting over
Old Nov 25, 2020 | 04:05 AM
tinymike66's Avatar
tinymike66
Default Converting over
Hi folks.
so I'm converting over from MM EFI to carb.
Current:
2001 Ultra , 95ci kit , SE heads, SE 257 cams , SE cam plate & hydrolic tensioners, HV oil pump.
Rienhart 4" 2 into 1 exhaust.
I obtained a complete wiring harness, and ECM off a friend
I assume this would make this pretty much a plug & play with electrical.
I have the manifold, carb, choke cable and upper Mount with choke bracket.
Question is I don't think his old bike had cruise. Is there a way I can salvage my cruise or will I lose it converting over with the ECM and harness?
Thanks
Mike.
Old Nov 25, 2020 | 08:00 AM
Ed Ramberger's Avatar
Ed Ramberger
Originally Posted by tinymike66
Hi folks.
Current:
Thanks
Mike.
If the carburetor has the throttle cable bracket that accepts the cruise cable you should be fine. It looks like an extra cable groove with a nub the cable clips to. Be careful disconnecting it from the old intake as the plastic may be a little brittle by now.
The cruise module is not run through the ECM on that bike. Above you say you got a wiring harness and an ECM from a friend. The only thing that makes sense is that you got an ignition wiring harness and an Ignition Module from a friend.
If you don't have the carbureted ignition harness, you can get it from NAMZ.
What is wrong with your EFI?
Old Nov 25, 2020 | 09:26 AM
tinymike66's Avatar
tinymike66
No I got a wiring harness and actual ecm from a carbureted 01 Electra glide
I also have the spark plug box, coil
Right now efi is ok. But I'm planning on more mods and I prefer carb over efi.
MM is great when it works but I hear horror stories when it doesn't
Old Nov 25, 2020 | 12:23 PM
Zanthamos's Avatar
Zanthamos
Eds point with the ECM is that only EFI bikes have ECMs whereas carb bikes have Ignition Modules.
Old Nov 25, 2020 | 12:39 PM
tinymike66's Avatar
tinymike66
So then it must be that
So what I got was a full harness.
Ignition coil
Top engine mount
Choke cable
Manifold
CV Carburator
And a small rectangle box with two female pin plugs ...he said it's the computer
Old Nov 25, 2020 | 01:19 PM
eighteight's Avatar
eighteight
[QUOTE..he said it's the computer[/QUOTE]
Part # on that box will allow you to confirm or deny that it`s an ignition module for a carb bike.
( I mentioned in your other thread that that your proposed engine modifications "may" require a programmable ignition to alter the spark advance curves / Daytona Twin Tec is one such unit )
Old Nov 25, 2020 | 01:58 PM
tinymike66's Avatar
tinymike66
( I mentioned in your other thread that that your proposed engine modifications "may" require a programmable ignition to alter the spark advance curves / Daytona Twin Tec is one such unit )[/QUOTE]
I'll check that #
I think those mods might have to wait.
The heads I got don't seem to be compatible with a 98 or bigger build
There's a lot of research I need to do.
Old Nov 25, 2020 | 02:09 PM
eighteight's Avatar
eighteight
Your S.E. heads can be compatible provided you select the right piston & head gasket
'Someone" made it work with your current 95" !
Old Nov 25, 2020 | 06:37 PM
tinymike66's Avatar
tinymike66
Old Nov 25, 2020 | 06:43 PM
Ed Ramberger
That module is not for your combination, it is for a stock bike. The timing will be too advanced. Buy a Daytona Twin Tec.
