Fuel pump not running
Old Aug 1, 2007 | 04:12 PM
Win_Brad's Avatar
Win_Brad
6th Gear
Default Fuel pump not running
When I try to start my 2000 Road King Classic with fuel infection, sometimes the fuel pump will prime the engine and it will start immediately and other times I have to keep turning the ignition on and off until the pump engages. I have been told that it may be the fuel pump relay, but where is the relay located at and is there something else I should check?
Thanks
[IMG]local://upfiles/38972/ED61789B21D04A84A875654852E3D3BD.jpg[/IMG]
Old Aug 1, 2007 | 06:40 PM
beemer737's Avatar
beemer737
Default RE: Fuel pump not running
you may want to wiggle the connection under the seat that powers the pump, two piece white connector usually left side of tank, you'll see it when you take the seat off. For any tank removal, this connection needs to be unplugged so you can depressurize the fuel lines to remove the tank, if it's loose, it won't work. Relay is under one of the side panels, i think left, i could be wrong, don't have the manual right now.
Helrazor
Jul 6, 2021 08:10 PM
Hair53
Jan 1, 2021 02:21 PM
sepperl
Jul 19, 2020 06:21 AM
Bobbed Out
Feb 3, 2010 08:07 PM
tmac5854
Exhaust System Topics
May 18, 2007 04:19 PM
