driving me nuts
Old Feb 3, 2022 | 06:40 PM
Second Street Cycles's Avatar
Stage I
Default driving me nuts
got a 2008 heritage we just redid the engine on, wont start.... no spark.
crank sensor is new, injectors squirt, has power to the coil, coil is good, but no spark?
we OHM'd the wires from coil harness to the ECM harness and they check out
anyone got any ideas?
Old Feb 4, 2022 | 07:10 AM
hrdtail78's Avatar
hrdtail78
Are you checking your spark with plugs installed and using a third plug or a spark checker?
Old Feb 4, 2022 | 08:33 AM
burntoutbill's Avatar
burntoutbill
Stage I
Checking with plugs out, grounded to jugs
Old Feb 4, 2022 | 08:43 AM
jbarr1's Avatar
jbarr1
You will not get spark using that method. Must have a plug in the cylinder for spark to occur.
Old Feb 4, 2022 | 11:41 AM
nevil's Avatar
nevil
Get an inline spark tester at your favorite auto parts store, around $10. You need to have compression for the ECU to send a spark signal.
Should also check for codes.
Old Feb 4, 2022 | 06:01 PM
Ed Ramberger's Avatar
Ed Ramberger
Plug wires reversed
Old Feb 5, 2022 | 07:18 PM
Ed Ramberger
One and done anyway
Old Feb 5, 2022 | 08:07 PM
chopper_man's Avatar
chopper_man
Educate me please, how is the compression sensed? Only sensors I knew of in the heads were temp sensors and acr's on newer bikes.
Old Feb 5, 2022 | 08:27 PM
Ed Ramberger
ECM senses flywheel deceleration via crank sensor on compression strokes and cross references with MAP sensor and missing flywheel reluctor tooth to know phase. When you crank with no plugs it doesn't see the deceleration and will not throw spark.
Old Feb 7, 2022 | 07:42 AM
roussfam's Avatar
roussfam
Class dismissed
FWIW, I had no idea, lol
