installed usbpc111 2 questions
Old Aug 11, 2007 | 08:56 AM
dynamolowrider's Avatar
dynamolowrider
Default installed usbpc111 2 questions
I have 06 dyna big sucker& VH big shots 25deg inj,installed map 811-003.I extended the rev limit and noticed it only shows 6000 on the map file? second? is this map for the 8deg. inj.?
Old Aug 12, 2007 | 03:25 PM
Doc 1's Avatar
Doc 1
Default RE: installed usbpc111 2 questions
The 25* injector flows 15% more than the 8* injector. Did you have the 25* injector installed in your bike?
Old Aug 14, 2007 | 10:40 PM
dynamolowrider
yes when i bought my bike it had the 8deg inj. i got the bulliton 1185 and took it up to my dealer and had the 25deg. inj. installed. since i made this post i called tech support and spoke with them they only have one map for the 25deg inj. and it has a diffrent ecm part # they told me to adjust the mid and high buttons on the face plate down 2 bars.it also is a 5500rpm map so i just poke some numbers in.i want to hold off on the dyno tune untill i get my 37h cams.it runs way better than it did with stock set up but i still think it is a littel rich
HyperM3
Jun 10, 2019 03:57 PM
Diverrick
The Dyno Room
30
Jul 30, 2016 09:35 AM
hAkron
Sep 1, 2007 05:22 AM
Dogs of war
Feb 9, 2007 10:01 AM
eunrein
Jun 29, 2006 10:19 AM
