ignition problem
Old Jun 13, 2022 | 11:40 AM
Thrashed J's Avatar
Thrashed J
Stage III
Red face ignition problem
Hello I am from Russia. We are very bad with information on Harley. my bike is a sportster 1200 s. I was driving to work, the motorcycle began to twitch, at low speed I drove to the garage. The next day I started the motorcycle and saw black smoke. disassembled the carburetor, washed and blew, reassembled. the bike worked and then the spark began to disappear. At first it started up intermittently and then it stopped starting. as a result of the problem with the carburetor got a problem with the ignition. tell me where to start and what I might have done wrong. the bike is very simple with a minimum of wiring. keihin carburetor. sorry for my English))
Old Jun 13, 2022 | 12:00 PM
koolbreez's Avatar
koolbreez
bike is trying to tell you to get the **** out of Ukraine !!!!
Old Jun 13, 2022 | 12:02 PM
Thrashed J's Avatar
Thrashed J
Stage III
I hate what is happening. not all Russians want this.
Old Jun 13, 2022 | 01:15 PM
eighteight's Avatar
eighteight
Are you sure your carb problem did not foul the spark plugs ?
Make sure your battery is good and all connections clean and tight.
Old Jun 13, 2022 | 01:26 PM
Thrashed J's Avatar
Thrashed J
Stage III
I clean the spark plugs, the battery is new and I charge it as needed. there is no spark at all. I ordered a cam position sensor, I think it's broken
Old Jun 13, 2022 | 03:06 PM
hrdtail78's Avatar
hrdtail78
On the ignition pick up in your nose cone. If the potting material is soft or looks like it is melted. It's a good sign it's bad. Ignition being weak will affect your mixture. I would address ignition and see if carb problem still exist.
Karfelt
Electrical/Lighting/Alarm
May 14, 2020 01:05 AM
Sbess487
May 10, 2013 07:25 PM
axle357
May 7, 2011 08:16 PM
nathanbedfordforrest
Ironhead
Aug 5, 2007 02:38 PM
Alia1200
General Topics/Tech Tips
Jun 26, 2005 07:17 PM
