Performance ignition hp gain?
Old Jan 2, 2023 | 04:43 PM
dyna107375l's Avatar
dyna107375l
Default Performance ignition hp gain?
Would a performance ignition add hp and torque?
I have cams head work and a big bore kit along with a 2 into 1 and air intake 107” from 96”
making 114hp and 117 tq would like to squeeze a little more hp and torque out of it
any suggestions?
Old Jan 2, 2023 | 06:39 PM
Since 1968's Avatar
Since 1968
It seems unlikely if your plugs are firing with a strong spark already. Fresh plugs, good coils, and good, correct plug wires won't leave much, if anything for a different ignition system to pick up.
What you could do is index your spark plugs. That's supposed to be good for about 1 hp or so. You can buy a set of indexing washers (various thicknesses) and use the ones that place your plugs with the 'open' side of the plug gap facing the intake flow. Here's one source:
https://www.summitracing.com/parts/p...+5ba295f673048
Old Jan 3, 2023 | 07:32 PM
Slingshot383's Avatar
Slingshot383
If someone made a 2 amp coil for Harley's you would have more than enough spark power to any running compression you could put in the motor and it still hold together. You would also have to buy new spark plug wire on an annual basis.
Old Jan 3, 2023 | 09:40 PM
Max Headflow's Avatar
Max Headflow
The stock ignition is more than enough. HD needed a real hot spark to light off lean mixtures.. Set the AFR for power and you have plenty of spark unless you want to run a 250 psi cranking pressure.
2 amp coil?? The stock TC coil is 1/2 ohm.. Add maybe 1/2 ohm for wiring and it's still a 12 amp coil.
Old Jan 4, 2023 | 02:30 PM
marcodarq's Avatar
marcodarq
i am going to assume that this is a carbed bike. based on that assumption, the reason for a performance ignition system is to gain better control of ignition timing and advance slopes, to me. Sure the stock system will fire the engine, but you do leave hp and tq on the table without having the added control. Time spend on the dyno to dial in the perfect timing and the proper advance slope can have very good results. Also, a good performance coil can have advantages,,,not in the way most people think though. The advertised high power outputs dont really mean much,, what matters is the quicker , i don t know what the proper term to use here is so i'm going to wing it, the quicker it can refresh/recharge. at high rpm the better coils can have a better handle on this. This is also not opinion, but my experience learned on dealing with my turbo charged Porche. The MSD coil worked much better than the stock coil....I will try to find the correct wording for this and report back.
m
Old Jan 4, 2023 | 03:28 PM
Max Headflow
@marcodarq
Yeah you are right on about that.. I read it wrong in that case.. You definitely need an adjustable ignition.. The coil and plug wires are more than adequate.
Old Jan 4, 2023 | 06:56 PM
Slingshot383
Max Headflow, the factory coils are 12 volt, not 2 amp! A 2 amp coil will do serious damage to you if you get shocked by one. Factory coils step the 12 volts up to around 50,000 volts, but at low amperage, below 1 amp. If you look at modern NHRA blown fuel cars, they run a pair of 44 amp magnetos, World of Outlaw sprint cars use a 4 amp magneto for the 410 cu.in. fuel injected motors.
Old Jan 4, 2023 | 07:08 PM
Max Headflow
Not sure what you meant here then..
Old Jan 5, 2023 | 06:57 PM
Slingshot383
Max Headflow - If someone made a 2 amp coil for the Harley V-Twins, it would exceed the need for any street driven engine combination, and most racing combinations. Only the Top Fuel Harley's could use a more powerful coil. A 2 amp coil will ruin a set of RFI spark plug wires in about a year. The solid copper core wires would be a different story, but you won't find those on a motorcycle anymore.
Old Jan 5, 2023 | 08:05 PM
Max Headflow
I guess it depends on whether the 2 amps was on the input or the output.. After all the coil is nothing more than a transformer.
